Mini version of Scophony - its do-able
Postby Gregory » Tue Feb 09, 2021 5:00 am
Andrew Davie wrote:In 3D printing, it is common to have the print surface (a plane) adjusted by 4 screws in the corners. This always bothered me; a plane is *defined* by three points, and it is about these that the plane pivots when they are adjusted. So, I get the same sort of vibe seeing 4-screws in a mirror adjustment. I understand why so, but still bugs the purist in me! Keep up the good work; am watching your construction with interest.
I agree with you Andrew, a 3 screw adjustment, although maybe not quite as rigid is better and I did notice when adjusting the mirrors on the original line frame 8 sided mirror, that if I was not careful the mirror surface could be easily warped, as acrylic does flex slightly. On the next try I will use a 3 screw adjustment instead and see what happens.
Gregory
Mad Scientist
Postby smeezekitty » Tue Feb 09, 2021 8:16 am
One of my 3d printers has 3 screws to adjust build surface. I have to say it is _way_ easier to adjust it correctly with 4. 3 points define a plane but that doesn't mean it is the easiest to work with in practice.
Postby Gregory » Tue Feb 09, 2021 9:51 am
Andrew Davie wrote:Regarding micro-stepping in steppers this, too, has been something I've run across in 3D printing. The discussion there was the claim that layer height (the vertical stepping) should be a multiple of 0.04 mm. The argument ties down to avoiding micro-stepping the motor because it is inaccurate. The fundamentals are that the stepper driver is (depending on the brand) somewhat inaccurate at holding a motor at a micro-step position, and this translates to inaccuracies in layer height. While true enough, my analysis back in the day was that the actual error was too small to make any perceptible difference.
But in any case, interesting to see the same sort of thing being discussed in such disparate endeavours. Just be aware there is some positional error in microstepping, and this can vary between motors/brands. I could probably dig up the analysis/evaluation if really needed.
The Hackaday video is very informative. Hopefully the momentum of the mirror assembly and motor may assist in smoothing out inaccuracies of the micro-stepping. For the future, the 1.9 degree stepper motor would probably be a better option than the 7.5 degree motor I'm using for the line scan, as it would already have quite a high accuracy, even without the micro-stepping.
Gregory
Mad Scientist
Postby Gregory » Tue Feb 16, 2021 5:12 am
The missing pulse restorer and frame separator are nearing completion and I should start testing soon.
However the line scanner with the 7.5 degree stepper motor together and 15 sided mirror troubles me somewhat as it will not only require a 2 stage multiplier, but will also require some way of phasing the mirror position with the incoming sync signal. This will need, at the least an opto sensor on the mirror together with the necessary electronics to achieve correct phasing.
One possible alternative solution would be to couple the motor to the mirror via a timing belt to provide a speed ratio of 15:48
As the mirror has 15 sides and the stepper motor has 48 full steps per revolution, with this ratio then 1 full step would equal 1 line scan, and thus the stepper motor could be driven directly from the line sync pulse.
Although this would theoretically mean lower output torque, because the stepper motor is operating at about a third of the original speed, the torque from the motor would be far higher and substantially compensate for this.
If this works the lines scan signal could drive directly the stepper motor and no phasing or Opto-sensor would be required, apart from setting up the initial angle position of the mirror to coincide with the start of the line scan. However the stepper motor would still need to be slowly accelerated to near the required speed, before syncing
So decisions, decisions, I have just ordered on eBay the timing pulleys, belts and idler pulleys required, and if it works (A BIG IF) this would simplify things substantially, for the line scan.
Any feedback or thoughts would be welcome, as I'm not sure if this will work.
The frame scan would still have to be done using the multiplier, as the speed would be too slow for smooth operation using full steps mode.
Gregory
Mad Scientist
Postby Harry Dalek » Tue Feb 16, 2021 12:44 pm
viewtopic.php?f=1&t=1795&hilit=mirror+camera
View this page this is how i did it and it worked very well using an opto switch !
Postby Gregory » Sun Feb 21, 2021 3:21 am
The missing pulse restorer is now fully working giving a continuous sync pulse, although there were some errors on the original schematic previously posted. I have now revised the schematic in the previous post as also shown below:
missing pulse restorer 3.jpg (28.81 KiB) Viewed 182 times
The restorer has been tested and setup for 30 lines (375 hz) and 60 lines (750hz). Other line/frequency resolutions can easily be added, with only one 22k preset required for each additional line/frequency resolution. The frame line resolutions has been kept at 12.5 hz which seems to be standard for most NBTV formats.
sync separator and missing pulse restorer.jpg (95.95 KiB) Viewed 180 times
Oscilosope traces for the missing pulse restorer
The top trace is at the output of the first 4098 and the bottom trace is at the output of the restorer
30 LINES 375 HZ RESOLUTION
60 LINES 750 HZ RESOLUTION
The next stage is to connect and power up the line scan stepper drive and see how the line scan stepper motor reacts at 375hz and 750hz frequencies using a signal generator, and if all is well, try to run the stepper motors directly from the sync pulse signal.
Gregory
Mad Scientist
Postby Harry Dalek » Sun Feb 21, 2021 8:24 am
Gregory what at the part values in the circuit ,a good circuit always comes in useful to us experimenting.
Good luck on the steppers !
Postby Gregory » Sun Feb 21, 2021 10:06 pm
Harry Dalek wrote:Gregory what at the part values in the circuit ,a good circuit always comes in useful to us experimenting.
Harry, Values for the restorer are as below. You can change the values of the RC combination, as long as the time constant remains the same. I used these values as I have loads of these, especially the 22k presets.
C3,C1 33n
C2 470n
D2,D1 1n4148
R1,R2 22k VAR
R4,R3 22k
R6,R5 47k
SW1 SW ROTARY 2P-6W
U1,U2 4098
The reason I did not include values, is that the frame line separator needs to be finished yet. I am hoping to get the frame pulse in a different way, by using an exclusive or gate. If this works, the frame separator can be used with any line scan frequency/frame rate combination, without any additional switching.
Gregory
Mad Scientist
Postby Harry Dalek » Mon Feb 22, 2021 3:56 pm
Gregory wrote:Harry, Values for the restorer are as below. You can change the values of the RC combination, as long as the time constant remains the same. I used these values as I have loads of these, especially the 22k presets.
C3,C1 33n
C2 470n
D2,D1 1n4148
R1,R2 22k VAR
R4,R3 22k
R6,R5 47k
SW1 SW ROTARY 2P-6W
U1,U2 4098
The reason I did not include values, is that the frame line separator needs to be finished yet. I am hoping to get the frame pulse in a different way, by using an exclusive or gate. If this works, the frame separator will work for any line scan frequency (using the missing pulse) and so the separator can be used with any line scan frequency/frame rate combination, without any additional switching.
No problems Gregory thanks for posting what's made so far ,i had a similar problem with my crt monitor using Steve's circuit it will now frame from 23 line to over 100 lines .. Keep going it will be nice to see it displaying in sync .
Postby Gregory » Wed Feb 24, 2021 9:39 am
Just tested the frame line sync separator on 30 and 60 line resolution and all works fine. I have combined all the separate schematics into one, as below.
The pre- amp and line scan separator are copies of the Klass pre- amp and the NBTV sync separator. I have added to this the missing pulse restorer and frame line separator I built.
J
The complete separator has the following options/features
Connector outputs
1) Line scan sync output (with no missing pulse)
2) Line scan sync output (with the missing pulse)
3) Video output with restored DC level
4) Frame scan sync output with no phase delay. Operates with any lines scan frequency from 300hz to 800hz (6 switchable pre-set selections)
Front panel Controls
1) Amplifier gain
2) Frequency selection switch
Connector Inputs
1) 2 way connector for 12v DC
2) 3.5 mm Jack socket for Video input
As the breadboard construction is somewhat fragile next task is to design a proper PCB to replace this. This would also be a useful building block, that can be used on any televisor, and for future projects. When finished I will post all the details including the PCB artwork, components layout and parts list, for anyone that is interested.
Gregory
Mad Scientist
Postby Harry Dalek » Thu Feb 25, 2021 4:46 pm
All looks great ,good idea to make this usable on a future project plug in i suppose ,thanks for the schematic i like trying different designs i will get around to trying it in the future.
