by Steve Anderson » Tue Dec 10, 2024 1:37 pm
Generally there isn't any attenuation of the baseband NBTV signal. As the bandwidth is so low, much the same as an audio signal, the impedance of any cable/connectors etc. is generally ignored. Sources are low-Z and inputs are high-Z. There is a nominal signal level of 1V peak-to-peak.
But it's up to each user/constructor to define his/her own in-house standards. I generally stick to 75 ohn in and out at 1V p-p including composite syncs, but there's no real reason to do so, and most don't. If two members want to construct NBTV equipment which will interface with each other it would be prudent to agree a standard at the start. This also applies to other signal parametrs, like voltages, frequencies, timing, line quantity, generally all normal signal standards that require definition.
I think that generally sums up the situation, but if I've missed anything, just ask....
There is a broadly defined 32-line 12.5Hz NBTVA 'standard', but not everyone sticks to it, I have used different line quantities many times, e.g 32, 48, 72-lines at various frame-rates with various frame and line-sync arrangements.
The bandwidth of 72-lines at even 12.5Hz is getting slightly outside what could be called 'audio', but not quite what I would consider 'video'....even though it IS a video signal!
