AncientBrit wrote:Or even free standing components soldered to a few insulated standoff pillars. Graham
Lawnboy wrote:....is the dome photocell really a giant photodiode as the newsletter says? would this amp work for solar cells as well?
Lawnboy wrote:i will look through the archive CD again to see if there is a "newer" or "imporved" version before i start building it.
Lawnboy wrote:i was wondering if it had a high enough frequency response for 32 lines.
Lawnboy wrote:you used the head amp circuit from the handbook? i guess that means the layout diagram i made is no good. (or ive developed a nasty habit of hooking up transistors the wrong way )
Apart from the BC109C the other transistors can be generic types. The BC212 could be replaced by a BC556/7/8 in any grade, i.e. any suffix A, B or C (or no suffix at all), or a 2N4402/3, almost any silicon PNP device will (should) work. As you're US based also the 2N3904/6.
Lawnboy wrote:Steve, isnt a 2N3904/6 an NPN transistor?
Users browsing this forum: No registered users and 43 guests
