Klaas Robers wrote:I would have designed the circuit such that there is a reverse voltage over the diode. This increases the efficiency of the photo effect and it gives the diode a smaller capacitance.
Agreed. But to be quite honest I still don't really know what this 'dome sensor' is. Is it a photo-diode, a photo-transistor, or as Jeremy put it, "They are miniature silicon solar-type cells, like BPW81/A, SFH 2030 etc." The SFH2030 is a photo-diode, the BPW81 has a Schmitt detector circuit built in and neither is what I would call a solar-type cell....so I'm confused. What doesn't help is the lack of a datasheet or even a manufactures type number.
If I do make it to the convention this year (there's an 80% chance of that) I'll ask if I could purchase a couple of these devices and do some tests on them when I get back home.
Without an example of one of these devices it's hard to discern which mode it's currently being operated in. If the 22k pot wasn't there and the amplifier had a much higher input impedance it would be operating in photo-voltaic mode. This is not the best mode for this application as the open circuit voltage roughly only doubles for a hundred-fold increase of irradiation.
But with the pot and the amplifier it's 'sort-of' operating in a photo-current mode with the load impedance converting that into a voltage...almost a transimpedance mode.
As you suggest, and assuming this is a photo-diode and not a photo-transistor, reverse bias would reduce the junction capacitance and convert the device into a photo-detector whose output
current is a linear function of illumination, but making allowance for 'dark current', i.e. leakage.
So now it's a current source, that is a very high impedance source. To maximize the output
voltage the load impedance needs to be as high as possible and to preserve frequency response stray capacitance needs to be minimized.
Without wishing to be critical using a bipolar device with a source impedance of this magnitude doesn't yield a very good signal-to-noise ratio. With low impedance sources bipolars are best, but here a FET wins hands-down when dealing with meg-ohm sources. Here you're dealing with
noise current, not noise voltage.
Also of note is that the BC109C was good in its heyday (the 70s), it now is easily surpassed by the likes of the super-beta MPSA18 or the KTC3200 both with noise figures under 1.0db as opposed to 4.0db. But as mentioned before only really usable with sources of 100k or less.
Of the FETs I've used the quietest one to date is the Toshiba 2SK30, it is specifically designed for high impedance audio applications, capacitor microphones for example. Another contender is the 2N5457, although not marketed as a low-noise device it does a pretty good job. MOSFETs even with their amazingly high input impedance have too much capacitance for this task and are generally much noisier.
