by dominicbeesley » Thu Aug 09, 2012 10:14 am
Right got em, they were on this machine anyway - just had to reinstall Kicad.
Right, one thing to check (which is not entirely clear from the new schematics) is that the U, V inputs to the phase detector sub-circuit on the subcarrier circuit should be connected to the "SC Clock U" and V outputs of the clock divider...not actually wrong on the circuit but a little confusing as U, V labels are used on other pages and it had me going a minute ago.
You should be able to do roughly what I said before but the labels are now different.
You should break the circuit at C1103 as marked on diagram and if everything is working as it should you should then be able to vary and reverse the strobing effects by adjusting RV1101. You're aiming for an almost stationary set of colours and for the colours to be the same all the way down (or along if you're in portrait mode) the colour bar. If the colours are not the same along the bar but stationary then your subcarrier-oscillator and video source burst signals are out by a multiple of 12.5Hz (see notes on side lock 5.1 of televisor website section). Keep adjusting one way or the other until you minimise the number of colour changes and speed of strobing.
If that doesn't work try adjusting L1002 on the oscillator board with the RV1101 near its mid-point to set the oscillator's mid-frequency. Then repeat, you may need to actually get L1002 adjusted on centre nearer one end of RV1101's travel than the other but try middle for now. Then repeat the previous paragraph, you may need to mess around with these quite a bit to get it all working reliably but once set up they can be left alone.
All this would be easier if you can measure the frequency exactly - does your scope have a frequency counter built in or do you have an accurate counter (i.e to 100 or so Hz accuracy at 6MHz) and to about 1Hz at 15kHz?
If you can't get the lock to work or it side-locks: are you playing back from a computer or a CD player. I have a number of CD players that play substantially slow or fast - they need to be very close to spot on for this to work. Some use crappy ceramic resonators to set their reference speed and are so bad that I'm told they drive people with "pitch perfect" hearing crazy!
A good way of checking them is to burn a CD with a test tone say 10Khz using something like Audacity and scope this and check the accuracy (again this needs to be a lot of decimal places to make sense). Really the 15Khz burst needs to be within a few Hz of 15Khz.
If you play back direcy from a PC, Laptop or tablet (even my phone will do it) it should usually be close enough.
Let me know how you get on...
D
