Well, maybe not a few months... more likely a few weeks. I'm now up to slat No. 25. Another 95 to go! You can't see the actual reflective surfaces in the picture.
Each slat is numbered so I can ensure it is assembled next to the same neighbour it had when they were all ground and polished as a block.
The slats' other sides are being blackened by two applications of a permanent black marker pen. I'm hoping this will be more reliable than the previous method using matt black paint (and undercoat), which tended to flake off.
Each slat is located by two brass pegs on either side. Each peg passes through a run of three slats below it. In this way the whole assembly is rigidly interlocked... comforting to know when the whole thing is whizzing round 25 times a second!
Each peg has to be specially made and then carefully teased into its hole. It's a fairly tight fit, so this can't be rushed.
I'm building up this new screw while leaving the bottom thrust and radial ball races in position. The upper (radial) one is supposed to be a sealed type, but I want to take no chances with grit entering, so it's covered with a temporary plastic sleeve and kitchen paper.
I'm very glad I had these slats professionally ground and polished. I think the picture will be much clearer as a result. However, 0.3mm of metal was removed from each one. This is to the side (the short dimension), so the balancing should not be too greatly affected. In any case, once the full 360 degree corkscrew of them is finished, all the errors should cancel out.
A Mirror Screw has a strange beauty all its own. As it grows, it becomes more and more attractive to behold - a sort of reward for the fag of building it.
