The long-winded laser setting and locking compound pouring process (at just three slats a day) proved to be forty wasted days! There was a standard error in all the settings. I still don't know why. The end result was the mirror screw had to be taken to pieces once again.
At my wit's end, I then reassembled the screw over two days without any indexing at all. The slats were merely positioned roughly and the stack was clamped end-to-end. The whole assembly was then spun up and angular corrections made 'to order' with the setting tool I had made previously - an adapted long nose mole grip with a locknut added, intended to 'click' the slat edges into their correct positions. Since their grinding and polishing, the slats are now slightly tapered in shape, which further complicated the process.
Anyway, after a fair bit of fiddling around and hours of running the screw (which seems to further improve the positions), the slat positions became not too bad. The last thing was then to connect up Karen's brilliant Timing Corrector box and spend an hour or two adjusting the final position of each line. Karen's box generates its own test signal for this process.
SUCCESS! I spun the screw up this afternoon and have watched extracts from the 1946 technicolor musical "Till The Clouds Roll By". The pictures still require slight improvement but already they are great to watch... lineless, sharp, contrasty, colourful and 'limpidly' clear. The only thing that spoiled it was failure of the sound channel. To be fixed tomorrow.
Going to 120-lines has definitely been worth it! The 12-inch colour picture can be viewed like any 'normal' television. It's good enough to satisfy non-enthusiast viewers. It's far better than its 60-line predecessor.
I aim to bring this to the Convention, but because the facilities tend to be cramped for a display that will require more than four metres of clear floor space, I'll have to ask if somewhere special can be found where the it can stand.
Karen has put in a lot of work - and ingenuity - into her TC 'box', all done for nothing in return, and it has proved essential.
This achievement of 120-line colour mechanical television should therefore be seen as half Karen's - half mine - a combined effort. Oh, and we mustn't forget Steve A, whose original electronic design still lurks within... and seems well up to the job of providing the necessary bandwidth.
