Hi folks,
I wonder if anyone could clarify some details regarding the use of photo multiplier tubes please?
After reading a few back issues of the NBTVA newsletter I note a number of warnings which state that a photo multiplier tube can be instantly destroyed if exposed to daylight while switched-on.
While I can see how excess current might flow in the final anode due to the huge electron multiplication would it not be possible to simply include some form of current limiter to ensure that the device will simply saturate if exposed to daylight and limit any pottentialy damaging currents?
It has also been said that exposure to daylight (even when not switched-on) can degrade the performance of the photo-multiplier for days at a time until it settles down again.
Trawling the net has uncovered conflicting accounts with some writing that exposure to daylight (when switched off) does no harm at all and that photo multipliers are electricaly very "rugged" while other texts seem to imply that an old tube will almost certainly be U/S or below full spec due to mis-handling.
Are there any group members with genuine experience of using/handling photo multiplier tubes and if so could they confirm/deny the scare stories. I am thinking of making use of a 931A photo-multiplier tube but only if its likely to be of any good. While the tube is brand new (old stock) I have no way of knowing if its been out-of-the-box in daylight though it does appear to be un-opened.
Many thanks,
Des (M0AYF)
