holtzman wrote:However if you CONVERT digitally from 41 to 48 or reverse, there will be issues with quality.
holtzman wrote:We never feed our mechanical tv with digital pictures, we just store the analog signal in digital formats.
holtzman wrote:And there are no pixels at all in analog tv, only the line number and the shape of light spot which travels along these lines.
Lowtone wrote:The video2NBTV software didn't get the 32×48 videos right.
Lowtone wrote:I didn't try 60 line yet. But i really want to see 96㎑ on 32 line. It could ( maybe ) be a good way to store the files before converting to other formats.
gary wrote:In what sense do you mean it's not right?
gary wrote:I can assure you it does create it in that aspect ratio, but keep in mind that it has to incorporate the line sync width also and those pixels are lost to the overall picture (of course).
gary wrote:Increasing the sample rate will NOT increase the resolution (or quality) because the NBTVA standard has a bandwidth of approximately 10kHz so 44.1kHz is already more than adequate to carry that.
Of course if you decide to create more vertical pixels (but maintain the picture aspect ratio) that is a different matter - but then it is NOT NBTVA standard.
Lowtone wrote:When my AVI files are in 32x48, in many programms, like windows media player, or Video2NBTV, the picture is belived to be 4:3 format and is distorted. So i use 64x96 and it is nice.
Klaas Robers wrote:And no mechanical monitor can display it.
Lowtone wrote:The vertical resolution is better thant 32×48 after converting in NBTVA standard.
Lowtone wrote:The 32×48 videos were distorted in width ( like when you have 4:3 on 16:9 tv and distorted option )
The 64×96 videos are fine. The vertical resolution is better thant 32×48 after converting in NBTVA standard.
Lowtone wrote:I was trying to find the best way to produce videos for nbtv in digital, by making small files as close as possible to the format.
Lowtone wrote:My AVIs runs at 12.5 fps.
Lowtone wrote:The only problem i see is, when i play the WAV files through the Big Picture, sometimes the picture is not as accurate as the original.
Users browsing this forum: No registered users and 70 guests
