Steve Anderson wrote:Bicubic.... but in one axis only, X or Y, but not both.
Which, BTW, is ideal for NBTV where the resolution in one direction (e.g. the vertical direction for most Baird formats) is much greater than the other. In fact the vertical resolution in a mechanical nipkow disk arrangement is only limited by the height of the aperture and is theoretically infinite if you could make an infinitely small (in the direction of scanning) aperture, and produce an infinitely bright modulated light source. None-the-less, given these obviously practical limitations, it can be shown that an "optimised" aperture will always have a smaller dimension in the direction of scanning than across it. It is the transmission medium that normally reduces the resolution in the scanning direction (for obvious practical reasons), and it is conventionally assumed that the resolution in the scanning direction need be no greater than that across it.
The sharpening effect of image processing systems is really just a form of what we call aperture correction and is not increasing the bandwidth of the image but just lifting the high end that has been reduced by aperture distortion or some other form of (low pass filtering) processing.
Steve Anderson wrote:P.S. OK, fast-panning motor-sports are a no-no for mechanical TV, think of the gyroscopic stresses on an aircraft propeller and crankshaft when doing aerobatics! No difference really.
hmmm, whilst this is obviously true when discussing the conventional construction of mechanical cameras, there is no reason I can see why the cameras optics could not be panned independently of the moving scanning device. In fact the optics are very often 90 degrees out of phase with the (most often) rotating device.
I admit though, that I can't think of a single example of such an arrangement.
