But you are using the same sensor as I do aren't you? and paper is paper, ink is ink - what on earth could be different?
Yes i have no idea gary 330 ohm on the ir led and 22k on the emitter of the photo trany ..must be a reason more than likely a silly one i have missed ...
Have to point out last night all i did was replace the that encoder i didn't play with the light reflective sensor distance or any thing ..i would like to work it out as its easier for me to have a print out with out cutting slots out and it would work better as well.
Sorry about obsessing but silly things like this annoy me and I like to determine what the actual cause is even when there is an easy work around.
mmmm yes don't worry i don't like this problem as well has to be a reason... all i can think of doing is using a black texta on one or a bit of paper and seeing if its enough to trigger the bugger between the white and black .
I still suspect the reflectivity of the paper itself - most sheets of paper have a gloss side and a matte side - could this be the case in your set up?..
I am pretty sure the papers matte both sides gary but i will double check that ...i know it really likes a gloss so type of paper could be the case as in my set up with cutting out the slots the paper white is matte and the cd is gloss black .
One other thing to try is to de-focus the sensor a little by moving it back from 5mm - but you may have tried that?
I will try but did not real adjustments for that encoder yet ...i will alo see if we have other types of paper for printing ..wonder if photo paper would be any good ...is yours just matte paper Gary ?
Edit:
I suppose you may also be allowing more current to flow through the transistor by using different a resistor value, so a pot or a higher resistor value may work.
Its some thing to try it would be any easy fix if it works ..i'm getting the soldering iron out today fix a 2 grounding problems so i will wack a trimmer pot .
I am not sure that you posted the encoder sensor circuit did you?[/quote]
Its in the PLL motor control circuit few post ago is it the same as yours ?
