Your reflective sensor is horizontal to the horizontal slot .
Mine is horizontal but my slot would be sort of angled vertical.
Yours is close looks at 5mm mines more looking more like 20mm but using it as is thats what worked .
The reflective sensor you sent has this written on it HOA1405-2 8839 Mexeco
gary wrote:Well that is definitely wrong as the optimum distance is 5mm (refer data sheet) - mine wouldn't work at 20mm, but yours may - and it does support the theory that your output is way higher than mine - are you absolutely sure that the resistor is really 22k and that the connections to the HOA1405 are correct? A close up photo would be good (peer review ).
gary wrote:That looks fine Harry - I'm out of ideas I'm afraid.
AncientBrit wrote:Harry,
"Black is Black"
Yes just next to the cd black its greyer ..black is black there are shades to it i suppose .I don't know whether this is relevant to your camera but I did find that ordinary ink jet 'blacks' are transparent to Infra red light.
Oh I think gary would be interested in this to..well that would be the reason we are both scratching our heads !:shock:A few years ago I built a Nipkow disc camera using the Club's dome sensor and to check out the HF response I printed out a 'fan shaped' resolution chart.
The results were very disappointing with poor contrast range.
I made a photo copy of the test chart and the results were markedly improved.
This is a very important bit of information for any one else making one gary and i might have the same type of printer but the brand and type of ink might be the reason hes works and mine diddly squat !I assumed that the fused toner employed in the photocopy were opaque to IR.
MMMMM very interesting i will keep this in my head !A better solution would have course been to add an IR filter to the optical path in the camera, thereby improving flesh tone renditions.
AncientBrit wrote:Hi Harry,
Yes the camera is still operational.
I locked the disc motor to 50Hz to 'freeze' any hum bars.
So you use the strobe disk for motor control ?..The locking circuit is a little temperamental though.
I think they all are and have there moments .Speed control pot needs handling gently to achieve lock with a bit of hunting.
I have been slack on this side of motor control till of late but tried a few times now so of going all out on this one,i not only want the motor controlled but that feed back loop to control my sync to the pc as a monitor or recoder works for the mechanical clock doing the sync but i want the sync crystal controlled ..sort of worked when i tried the other day pulse widths to wide picture was half size,i have wacked in a monostable to try again..It was written up in one of the earlier Newsletters.
AncientBrit wrote:I don't know whether this is relevant to your camera but I did find that ordinary ink jet 'blacks' are transparent to Infra red light.
Users browsing this forum: No registered users and 130 guests
