Viewmaster wrote:I have 'lifted' this photo from The 'NBTVA 2012 convention thread' links so I hope the author will forgive me.
But it does illustrate what I too am suffering from at present only even worse !
What causes the horizontal lines to be modulated by a kinda bent sine wave I wonder, whose frequency appears to be the frame rate ?
I have tried power supply smoothing etc, but to no avail.
Can the disc speed be rising and falling at the frame rate ? If so, why, as the frame lock here and on my set up seems OK.
Varying disk speed seems to be the only answer but I have put on an extra flywheel for even more inertia and it makes no difference.
Has anyone else suffered from this and did they cure it ?
Thanks.
Steve Anderson wrote:IGary may have some suggestions here on this matter...
gary wrote:I can't see how this can be caused by a variation in the signal in such a way as it to be NOT apparent when displayed digitally (i.e. by TBP).
Steve Anderson wrote:Ah! That data I don't have...does the same file play OK in TBP? That I don't know. I don't know where the source of Alberts files is/are.
What I was more driving at above (r.e. suggestions) was a known good source of test files such that without confirmation using a scope, the output from the PC or CD player should be as perfect as expected from a test signal.
gary wrote:Steve Anderson wrote:IGary may have some suggestions here on this matter...
I am 99% sure this is always introduced mechanically and almost certainly by eccentricity.
Albert, as the variation is over 360 degrees it won't matter where you are viewing it you will see the same thing - look at it this way, at some point in a revolution the (say) disk will be at it's zenith or highest point - at that time the aperture that is in the gate will be higher than it should be by that amount. When the disk is at it's nadir or lowest point the opposite aperture will be in the gate and lower than it should be by that amount - and so on in a perfectly sinusoidal fashion. Across the lines you would just see a some widening or narrowing of the picture I would have thought.
Viewmaster wrote:BUT, if entirely mechanical, why does the wavy line vary in shape and intensity depending on the various pictures shown?
Viewmaster wrote:Steve mentioned hum, but again that would produce a constant waveform on all pictures I would have thought?
gary wrote:Viewmaster wrote:BUT, if entirely mechanical, why does the wavy line vary in shape and intensity depending on the various pictures shown?
Whoops I missed that part - where did you see that?
Users browsing this forum: No registered users and 95 guests
