Gary commented on one of my videos saying I must calibrate the NBTV program before testing which I did using a NBTV converted video and then run the camera and still haven't been able to get the motor speed right for a smooth flowy video signal, am still getting stuck lines and such (too many words to explain it all).
aussie_bloke wrote:Just a quick little update on the NBTV camera, I have read about the lens theory on the NBTV site tutorials and have been communicating with Harry on his NBTV camera project and have promptly decided to opt to use a solar cell as an image pickup device opposed to phototransistors or other small photosensitive devices due to the fact condenser lenses are not that easy to get a hold of but hopefully I will pick one up in the not too distant future.
Hi Troy
Reading the newsletters most used solar cells..but no reason not to use the others..we can make one together the solar cell i am using came from a jaycar toy solar car ..i have others but they are to big for what i want it for.I admit using chrome cellophane around the LDR was a bit of a dumb idea as the light would bounce all over the place but I went ahead with it anyways for the hell of it with the remote possibility it might work haha.
Never know till you try i did read that one person thinks the ldr works better than the solar cells for a camera .
I suppose using a LDR using a diffuser size of the scan area so the ldr sees all of the scans as light flashes over all the area...so same idea in reverse for LEDS sort of ,but with the low light levels i do think your better off with a lens of some sort ...Anyhow Harry explained to me with solar cells having plenty of surface area that covers the scan area of the Nipkow disc eliminates the need of the condenser lens to focus the light onto a small area.
Well it works for the flying spot idea so i see no reason it seeing the same thing behind a nipkow disk as it works in front .
Anyhow till I can find me a solar cell or buy one the camera project is currently on hiatus, but have a couple of other exciting projects I am working on in the meantime which I'll soon post.
Klaas Robers wrote:The problem of a solar cell is its capacity (in nF). Due to the high capacity the solar cell is rather slow. That will attenuate the higher frequencies.
Any way apply a DC voltage to the cell in the polarity that it is not conducting (in the dark). That will make the capacity lower (it is a varicap as well) and will make the efficiency also higher. I don't know what voltage is possible for a normal solar cell, because it is a zener diode as well, but I think about 10 volts. the dome sensor can withstand several tens of volts.
I don't know the Pedro circuit diagram, I have to find that back in the Newsletter. It is important to know the DC voltage and the input impedance of the amplifier. Heavy negative feedback to the input can help.
On the other hand I don't like the metal lines on the surface of the cell. If you place the cell close to the disc (as close as possible) then you will see the lines in the picture you make. Remind that the picture is focussed on the surface of the disc. If that is where you place the detector close to, the picture is also sharp at the detector surface.....
Klaas Robers wrote:I found the Pedro circuit diagram in Newsletter 26/3. I don't like it because
- there is no DC voltage over the sensor,
- too many variable resistors, that is not necessary in a well designed circuit,
- I don't trust the feed back cicuit.
The feed back does not seem to work changing the resistance does nothing so far testing ...i will try collector to base feed back and see.
For R1 put in a switch to switch between 2 and 4 meg resistors theres sure is a gain change happening ...this might be one area a pot would be better to see its limits .
I don't think i have seen a head amp with this yet klass do you have an example talking about the dc over the sensor.After you have made a sensor and amplifier, test it in this way:
- Make a light tight box (shoe box).
- place the sensor with or without amplifier in the box,
- place a (red) LED in the box such that it can illuminate the interior of the box,
- modulate the LED with a square wave of 10 Hz to 20 kHz,
- and watch the output of the amplifier on an oscilloscope.
Oh i have done this sweep test on the other 2 head amps .. Gary sent me a sweep wav file ...the solar cell was not as good as the dome sensor in band width in the high end but they are still workable ...
I will try it on this one .For a 32 line camera the output signal should be constant in amplitude (100%) until 10 kHz. For more lines and/or higher frame rates it should go higher.
Ok thats something i didn't know i will keep that in mind.Then decrease the LED current and see how sensitive your pick-up system is. You should see the noise of the amplifier. Steve has done this for a photo multiplier tube. Very educational.
Steve Anderson wrote:With all due respect to Pedro I too find that pre-amp in 26/3 'messy' and agree with Klaas's points.
Poor Pedro
It works may have to many pots ...i am not sure the circuit is he's i think its a rework but i had all the parts gave it a shot .
Going more about what he says it does than how much i liked it i have made it ..i didn't put in the ldr to try as didn't see the point of that needed yet .Biasing the sensor is a simple fix, wire the 100k pot across the sensor to the positive supply rather than ground. Make sure the supply is very clan and well decoupled/bypassed. or make provision for such. Or use a 9V battery, no current to speak of will be drawn, but make sure the sensor is the correct way around.
Ok Steve thats some thing to try ..found listening to garys advice better run these things off battery for the start any way...
why is it the other dome sensor circuit club circuit is to ground as well..The first stage only has one pot for gain control, but I agree the biasing is hit-and-miss. It will vary with the individual specimens of the trannies as well as with temperature.
I m using BC108's had some of these ones handy scrapped from something in the past .The second stage has some 'lift' starting at mid-frequencies (C2 and the 500R pot), I wouldn't have called it a 'contrast enhancer'.
I was thinking he had had some control over this reason i liked it .
The biasing for the third transistor is a real no-no. The Hfe of a transistor is not a well defined parameter (unlike tube/valve gm) and will vary considerably. The specification for a BC109C is 420-800 (Philips) hence his suggestion in the last line of text of fiddling the value of R1.
I'm not sure of the function of the LDR, some form of AGC?
In fact, staring at it longer I don't think the second stage will work at all (I'm often wrong though).
Imagine removing the LDR and its 4k7 pot then assume the transistor is fully off and the 100k pot is at maximum resistance.
Voltage at point 'B' will be 2.75V with a +5V supply. Turn transistor on, replace the LDR/pt and that voltage will be somewhat less, perhaps less than half of before. I don't see how it could work unless there's a typo in the schematic as happened to Troy in a different thread.
I don't know if anyone else has built this but if someone has your opinion would be useful.
Users browsing this forum: No registered users and 77 guests
