Thinking about my Octagon
Postby Harry Dalek » Sat Aug 11, 2012 12:29 am
Having played around a bit now with laser projection i think with what i have made works better closer to a screen as close to the projection mirrors .
So as ever changed the design again this time closer with the laser power i am using which i think is a 10mw Uv laser from memory i have retried the
phosphorescent paint screen ..it for me gives a more pleasant screen to view with the uv laser ..white paper gives the brightest viewing but is a bit hash to view ,its more like viewing it on a scope tv slight lag depending on the 4 sided mirror speed so at the right speed its pretty much ok might of just lucked it with the laser power or brightness setting just right .
Heres a few pictures bit hard to take a great shot may see the bbc test card girl in the shots below , a short video as well try to do better these were my first tests after the redesign .
I forgot to mention i do also still have the red laser may see it on the end of the stepper motor .
Picture 362.jpg (133.62 KiB) Viewed 5619 times
Picture 375.jpg (104.8 KiB) Viewed 5619 times
Picture 382-crop.jpg (51.99 KiB) Viewed 5619 times
Picture 395.jpg (139.21 KiB) Viewed 5619 times
Picture 382.mpg
sorry for the poor camera work just up loading best that came out .
no sync still
(3.14 MiB) Downloaded 684 times
Picture 344.jpg (197.17 KiB) Viewed 5616 times
Picture 354.jpg (136.8 KiB) Viewed 5601 times
Postby Harry Dalek » Sat Aug 11, 2012 4:36 pm
Working a bit more on the phosphorescent paint screen i have found from tests having a back to the screen seems to work better .
I am thinking as tests i did when i first tried phosphorescent paint on glass it reflects back better with white paper behind i recall it worked good with a mirror background.
Also i am thinking going the other way with a black one i might get better shading so i need to try that .
I will up load a few videos that came out in room lighting .
Picture 399.mpg
test cart test the sync a bit off room light test
(1.87 MiB) Downloaded 694 times
Picture 430.mpg
clown room light test
(6.36 MiB) Downloaded 1466 times
Users browsing this forum: No registered users and 67 guests
