rommert wrote:Hi Albert.My display is roughly constructed in the way you discribe.
Deflection circuits using mostly 40xx circuits followed by transistor
buffers and the video circuit and sync separation from the design
from Klaas. The gamma correction calculated for maximum 160 mA.
(see my former post) The overload indication is blinking a led when
the input videolevel is exceeding the limits mentioned in the design
from Klaas. ( I use a potmeter on the input to accomodate for different
input levels )
I do not use a safety circuit untill now. The deflection circuits are
clocked by synchronised free running oscillators. If you monitor only
this oscillators, a disaster can still happen when a fault occurs in the
following counters etc.
Yes Rommert, that's something else I hadn't thought of if the actual counters go on the blink.
Both Steve and Gary have suggested possible solutions but I don't believe
that either scheme would have checked the actual counting?
rommert wrote:For test purposes I made dummy loads with resistors for both de-
flection circuits. ( one with 32 resistors and one with 48 resistors )
As you can see on the photographs from Dr Zarkov I connected the
led matrix with flatcableconnectors, so the matrix can easely replaced
by the dummy loads.
I too am going to use with same cable connectors as you. The dummy load idea is useful.
rommert wrote:My leds are 3mm diameter. When installed in diagonaly rows on
veroboard, the distance between each led becomes 2.54 x sqrt 2 mm.
This is abt. 3.5mm. Unfortunately the leds had a small rim on the
lower part which made them a fraction to wide. I cut this off with a
sharp stanley knife. Of course the veroboard has to be cut diagonaly
when the leds are mounted in this way.
I have 5mm dia LEDs which will just fit into 2 hole spacing on veroboard.
I thought at first I could stagger them higher/lower to avoid the flange/rim problem, but like you I will have to remove that flange at 4 points.
rommert wrote:I wonder if you also experienced color change when overdriving
the white leds.
They get so blindingly white that it is nor possible to tell. They are just white. I can see not tendency towards blue.
I would like to thank you again, Rommert, for drawing my attention to the light leakage between adjacent LEDs. Something I would not have thought of until too late.
With my LEDs an unlit one next to a lit one does show some illumination, so that's more work to prevent this from happening.
If it all goes well I hope to hang that antique frame (it's really eBay plastic!) up on the wall as a picture with a multi cable running down to the floor to the power supply/sync sep/clocking box.
But your own matrix really does look a very professional job which I cannot match, so I will hide all my workmanship behing closed doors
Thanks again for your suggestions and ideas.
