AncientBrit wrote:Thanks Harry, Albert,
EDIT.
The trouble is you "mechanical guys" make it look so easy !
Ah, if only I found the electronics easy.
One thing for sure, you will need a good bearing for the mirror drum to quietly rotate on without wobble. Old video recorders and ball races spring to mind.
A ball race doesn't have to be pushed into a tight fit housing where a lathe is required.
Although I was initially trained as a toolmaker I am a great bodge engineer.
For ball races, in the past, I have just put 3 screws and bolts spaced around the outside to bolt the ball race down on to a flat surface.
2 races mounted opposite each other with a shaft running through makes a good bearing/shaft system.
No lathe etc requiired. Just a drill and 3 nuts and bolts for each bearing.
I once made a 12 inch dia worm wheel for a telescope, out of a picador pulley with 3/8 BSF threaded rod pulled around the 'V' groove and pinned in.
Another sprung loaded threaded rod mounted at a slight angle formed the rotating worm.
Engineering is difficult without machine tools, bodge engineering isn't.
I'm sure Harry and I and others too will help you with suggestions as you get going on your drum. Good luck.
