Page 1 of 1
My first NBTV system
Posted:
Tue Jul 16, 2013 5:48 pm
by eyrope
Hello. My name is Michael, I'm 17 years old. I live in Russia. The chance to read online about a mechanical television and decided to do it with their hands. Disk made from vinyl records. Received the first image, but it's not what I expected. What I did wrong?
Posted:
Tue Jul 16, 2013 8:01 pm
by DrZarkov
Привет Eyrope! Добро пожаловать сюда в этом форуме.
If that is the BBC "eye" testcard, the solution is easy: The signal is inverted. Just try another CD-Player or computer soundcard as source of the picture. If that is not possible for you: it is quite easy to invert the polarity, there are several suggestions on this website/forum to do so.
Posted:
Tue Jul 16, 2013 8:48 pm
by eyrope
Yes, this is the BBC "eye". Signal I'll try to invert. Now do another disk with apertures smaller diameter. I want to get a better picture.
Posted:
Wed Jul 17, 2013 12:04 am
by eyrope
I changed the polarity and the picture was much better. Thanks for the hint, I would not have thought of. Picture mirrored. Can I fix this? Still image leaves and in the middle is divided in half. Later I'll upload the pictures of the TV and describe in detail all.
Posted:
Wed Jul 17, 2013 5:39 am
by eyrope
Put amplifier in TV housing. Appeared grayscale, but the contrast and brightness still not enough to fully pictures. Looking through this forum, you have great images. I'm trying to do the same. Довольно интересное занятие:)
Posted:
Wed Jul 17, 2013 8:10 pm
by eyrope
Posted:
Wed Jul 17, 2013 10:25 pm
by Andrew Davie
eyrope wrote:I changed the polarity and the picture was much better. Thanks for the hint, I would not have thought of. Picture mirrored. Can I fix this? Still image leaves and in the middle is divided in half. Later I'll upload the pictures of the TV and describe in detail all.
If you spin the disc the other way, your picture will no longer be mirrored.
Welcome aboard! Congratulations on your success
Posted:
Wed Jul 17, 2013 11:22 pm
by DrZarkov
That's why we are here!
To improve the greyscale/contrast I think there is no way around making your own video-driver instead of using an audio amplifier. Look in this forum for "Klaas 1 transistor video driver", there are several threads about it. It is very easy to make and with very good results.
I wonder if it would be possible to make a relative simple circuit around cheap russian valves like the 6C19N-B (in our letters: 6S19I-W), costs about 3 EUR, or the 2SH27L which is even cheaper and available in large quantities.
Posted:
Thu Jul 18, 2013 12:20 am
by eyrope
Я считаю видео драйвер цепи на форуме. Трубы, я не нахожу места. Хотя я постараюсь заказать по почте. Я живу в очень маленьком городке, и мы не имеем Radio Shack. Все детали взяты из демонтированного оборудования. Я уеду на несколько дней, все эксперименты пока приостановлено.
Posted:
Thu Jul 18, 2013 2:04 am
by DrZarkov
I understood you, but I answer in English, as my russian is not that good. I know that problem living in a small village, you have to order everything via the internet. When I was twelve and developed first interest in mechanical TV I wish there was something like the internet... But improvising was always a speciality of russian engineers, and they've made very reliable and good working things, even without getting always the right parts. .)
Which circuit did you use? You wrote it is from the forum, on the picture it looked like an audio amplifier.
You can find russian valves worldwide at Ebay or here in Germany in some shops like Oppermann Elektronik, who also have a webshop.
Posted:
Thu Jul 18, 2013 2:34 am
by eyrope
The photo below is an amplifier of computer speakers Genius. Excuse me for the bad English, sometimes I use a translator. When I get home, I'll do a video driver.
Posted:
Wed Jul 24, 2013 10:10 pm
by eyrope
I returned home. Changed the polarity and the picture turned upside down. But the mirror reflection of the past. I found a video driver circuit and PWM - the regulator.
Posted:
Tue Aug 06, 2013 2:35 am
by TelevisionDk
If your picture is mirrored don't spin the disc the other way around. The disc has to be mounted the other way around on the motor shaft.
