by AncientBrit » Wed Jul 17, 2013 10:53 pm
Hi Dom,
Not sure of the maths on this but here goes...
Your return signal out of the light detector after filtering will be a low level 1MHz carrier, amplitude modulated by the scene content..
Detecting this signal to produce the embedded NBTV might be a problem due to the low levels.
If you heterodyned this signal with either the 1MHz reference or a derivative, say 31/32 * 1MHz, you could down convert the signal to a more manageable carrier frequency before amplifying and detecting.
(A similiar process to that employed in a Direct Conversion Rx.)
I seem to remember you did a considerable amount of such RF work in your NBTV subcarrier experiments.
Edit.
Okay, forget the above, I have just re-read your post. I see you're thinking of a synch demod which is in essence my idea above
Kind regards,
