by Klaas Robers » Thu Oct 30, 2014 12:19 am
Sergei, it is because of the rotation mass of the disc that the synchronous motor is no more self starting. The best way to overcome this problem is connecting a small DC motor to the same shaft, or with a hub and a rubber band, which brings the disc into rotation and then switch on the synchronous motor. Then the synchronous motor is acting more or less as a synchronisation wheel.
However, a synchronous motor driving a Nipkow disc always shows some hunting. I have seen that frequently in the Nipkow discs driven by a bike dynamo (Dutch system). This is because the rotating magnet in the rotating magnetic field is a not damped system. A synchronous motor to drive a Nipkow disc, is seen by many people as THE solution, in reality it isn't. I have the feeling that with a DC motor running along with it, the hunting problem is much less. Then the synchronous motor may do with very little AC power.
