I attached some pictures and additional video with the correct orientation. The wheel and much of the electronics employed here come from the NBTV club shop with the exception of the power supply, that I purchased as a complete unit elsewhere. The view window is a dome-shaped 3 inch magnifying glass.
Now about the additional video attachment and so forth... I am displaying a 1924 recording of Calvin Coolidge converted to wav format using the Video2NBTV software. My computer is playing the wav file and outputting its signal through its headphone jack which is then split between the RCA inputs in the back of the TV. As you may notice with this new video I think I am closer to getting the starting line oriented properly. Only a small portion of what would normally be at the top of the screen is sitting at the bottom currently. I took the piece of black tape you'll see in one of the photos and simply moved it to another sync hole on the wheel and that white ring you saw in the first recording I showed you is the LED light shining through the remaining unblocked sync holes.
Another thing, do you notice how the lower part of the image has more detail than the top?? The top of the image has a lot of solid black lines and I have no idea why. Any guesses?
Now note well, I did not build this TV by myself. A couple of engineers helped me with it and one of them is an electrical engineer in particular so he handled most of the electrical aspects. So if you have any questions or comments about the specifics of the electrical setup please try to dumb them down a bit if you can and if I still don't know what you're talking about, I'll gladly forward your questions or comments to my electrical engineer friend who would be able to understand. Thanks!
