A long post now.
Let's explore this 'big disc' idea and try pushing it as far as it will go. The following should be considered as a 'thought exercise' rather than a formal vow to go ahead with it!
The aim of such a project would be to demonstrate the 'best' picture -ie. finest detail, flickerless, reasonably large and bright - obtainable from a practical Nipkow disc. The higher definition mechanical standards, which are available from the WC-01 converter, are all horizontal scan. Therefore the picture would be seen at the top of the disc.
To give convenient viewing when standing, the bottom of the viewing port should say, be 5ft 6ins above ground. Making certain allowances, this means a 5ft (1.5m) disk with its bottom rim about 1 ft above the floor. This would give sufficient clearance for a stout base for the viewing shield.
The viewing shield itself would cover the disc, act as a light shield and incorporate the viewing port, with magnifier. It would have sides that 'wrap round' to prevent any possibility of touching the edge of the disc, which would be rotating at hundreds of mph.
So we have a 5-foot disc. Such a disc would require a lot of power to rotate fast against windage. It would also be heavy! The weight and (presumably) the windage could be reduced by making the disc of a vaned or 'spider' construction. But this would also reduce the strength.
The aim is to demonstrate the best Nipkow picture practicable. So how fast should it rotate to give reasonable freedom from flicker while keeping the speed to a minimum? For a bright colour display, 12½ Hz is really a bit flickery, as visitors will see on Saturday if they look at my exhibit. However I would want at least a similar picture size with this giant disc.
One advantage of using a very large disc with a 'high' definition mechanical standard would be that the characteristic 'Nipkow' keystone picture shape distortion would be very small. The picture would look, to all intents and purposes, rectangular.
The best match out of the WC-01 looks to be the 96-line standard (1932), with a 6:5 picture and a 20Hz frame rate.
Now we switch to metric units. The circumference of the disc at the centre of the picture would be 415cm. Therefore the picture would be 415/96 cm wide, or 4.3cm... somewhat less than 2 ins. This size is similar to what I have been working with - and magnifying - with the Grosvenor. However, given a similar aspect ratio, it now consists of 96/30 squared or 10 times as many pixels. Whether the picture would be ten times dimmer too, I don't know, since although the area of each pixel would be 10x less, there would also be 10x as many of them! Maybe someone wiser out there can comment? Anyway, the present luxeon display on the Grosvenor is plenty bright enough and can be viewed in subdued daylight. If we consider a display 10x - or more than 3 camera stops - lower in intensity, this should still be OK.
This brings us to laser cutting tolerances. These are generally reckoned to be ±0.1mm. For 96-lines, the square holes (actually now a rounded square) on this disc would be 0.45mm across. So there could be some blurring of the raster lines here... If this is random, it could be OK. However laser cutting errors tend to be periodic, so we could see some horizontal brightness banding on the picture.
What about the mechanical stresses on the disc? From
http://www.centrifuge.jp/cgi-bin/calc-e.cgi we can see that, at 20Hz, there would be 1220 g's at the rim. This would mean several tons of stress distributed inside the disc. Hairy!
The edge of the disc would be travelling at 214 mph or 345 Km/h. Still well under the speed of sound though, so no shock waves!
I don't know what the insurance at Loughborough covers, but to date nobody has raised any concerns about safety, even with my mirror screw, which was a brutal chunk of jagged, spinning steel. That might have to change!
