McGee2021 wrote:I was wanting to make a television, but this time without sync. I was wondering if it would be more complex, if even possible. And, if possible, would it need continuous adjusting?
McGee2021 wrote:Another question. Where could i buy a motor similar to the original Baird motor? Or would i have to make one myself
Klaas Robers wrote:McGee2021 wrote:Another question. Where could i buy a motor similar to the original Baird motor? Or would i have to make one myself
I know that Dennis Asseman several years ago found a source of comparable motors. I think they were meant for sewing machines. Old sewing machines have an electric motor fixed against the body of the machine and a loose pedal to control the speed. These motors are comparable to the Baird televisor motor. I think you have to buy an old sewing machine on a flee market, release the motor and discard the sewing machine.
But be carefull. They run directly on the 230V mains voltage......
McGee2021 wrote:I was thinking that i could make an electromagnetic sync mechanism. Since the club disk isn't magnetic, i would install magnetic bolts in the sync holes and when a set is in operation, an electromagnet would be mounted somewhere on a TV near the bolts. the electromagnet would be powered by a optoswitch at a transmitting disk
gary wrote:McGee2021 wrote:I was thinking that i could make an electromagnetic sync mechanism. Since the club disk isn't magnetic, i would install magnetic bolts in the sync holes and when a set is in operation, an electromagnet would be mounted somewhere on a TV near the bolts. the electromagnet would be powered by a optoswitch at a transmitting disk
Yep, it's been done (as has almost everything ) - see the NBTA newsletter collection.
Users browsing this forum: No registered users and 40 guests
