McGee2021 wrote:While visiting the Early Television Museum a while back, I saw a replica Baird televisor with a nixie substituting for the neon plate. I was planning to use a large IN-18 tube for the neon. I would buff the surface of the glass to make a make-shift built in diffuser and assemble all of the numerals to be connected so it would emit more light, as they had done with the replica
Here is a link to the replica:
http://www.earlytelevision.org/baird_kit_copy.html
McGee2021 wrote:Seeing that I have many tubes at my disposal, I would buff the surface of it slightly and add a difuser film to spread the light out a little bit more. The tube that i plan to use, because it is so large, is an IN-18
Steve Anderson wrote:If you reverse the polarity the digits won't glow, it will (should) be what normally is the mesh anode (now the cathode). This should have a larger surface area and mass compared to all the digits so it should be safe to run at a higher current - though not too excessive.
Harry Dalek wrote:Think Andrew would be wondering about that calculator the Russian ones are part of he's Hobby.
McGee2021 wrote:Harry Dalek wrote:Think Andrew would be wondering about that calculator the Russian ones are part of he's Hobby.
Judging by how many boards it has, two of the devoted to memory, it would had of been a very large and expensive calculator in its day. Im missing about half of it, including the case, the powersupply, and part of the wiring harness. Im supposed to go back today and venture through the cluttered house in a search for the rest of it. I'm also going back to rescue a very early portable generator with a very large motor and dynamo.
Users browsing this forum: Ciupi84 and 39 guests
