Steve Anderson wrote:Hi Jimmy and welcome to the forum.
Quite an ambitious start at 60-90 lines. I would suggest starting out with a 30/32-line version first, you can always change the disc in the future. The reasons I suggest this is there's less precision required with fewer lines and there's a large amount of material around to play back and view.
There are some here who do have the ability to generate 60-line NBTV files but you'll have to ask them to do it for you...unless you already have some existing material.
I wish you all the best with this and I hope others will jump in and help when you need it. Good luck!
Steve Anderson wrote:Quite an ambitious start at 60-90 lines. I would suggest starting out with a 30/32-line version first, you can always change the disc in the future. The reasons I suggest this is there's less precision required with fewer lines and there's a large amount of material around to play back and view.
reshiram202 wrote:Wish I could use a standard RCA video cable instead of audio files.
reshiram202 wrote:Here is my scanning disk made out of cardboard. Is it good? Is it bad? I don't know. I reeaally don't want to restart but if I really need to I will.
Users browsing this forum: No registered users and 44 guests
