Klaas, you are the first in line so I will start with your comments. I thoroughly understand the points you are making. All I can do at this point is state the exposure times provided by the camera control software. Your measurements would suggest that both are very close to the claimed values. As far as frame rate is concerned, I am reporting the values indicated by the VirtualDub software. If you are puzzled by the previous videos, this one will really have you going back to your calculator.
For this video, I took the entirety of the original .WAV file, displayed it on the 32-line Nipkow monitor, and imaged with same monochrome CCD camera. What is different this time is that I used the capture function of VirtualDub to minimize the number of programs used. I captured and cropped the video in a single operation. I took a lot of time to set-up the camera and this is certainly the best-looking version to date. Because I was using VirtualDub with the camera, I could rerecord the audio track as I was making the video. So the result is both sound and video.
Now here are the numbers that you won't like:
(1) The video exposure rate was set at 1/13 s. and the width of the under-scan certainly suggests that is reasonably accurate.
(2) Original recording frame rate was 30 fps! This frame rate was set by the VirtualDub software and I made no attempt to change it as the recorded image was looking better than anything so far.
(3) Since an audio track was being laid down in real-time, there is a significant chance that any later changes in frame rate would make problems with the audio - something that VirtualDub warns against!
At the end of the processing, the final AVI was reported to have the 30 fps frame-rate, which makes sense since the audio track was unchanged.
BTW, the output AVI would not play on WMP, more on that later. I ran the output AVI into Live Movie Maker, which does accept the AVIs, and outputted the file in the .WMV format. The frame rate appears to be the same as the original AVI, as supported by the integrity and sync of the audio track and the fact that 30 fps is the default output for the LWMM - hence the rapid movements is some of the earlier tapes.
How the system uses 1/13 s. exposures and creates a 30 fps video stream is quite beyond me at the moment, but it is hard to argue with the image and sound on the video. I think there is some creative buffering and formatting of the video data stream, but I have not arrived at a satisfactory explanation. Fortunately, my ignorance does not trump the reality presented by the recording.
Anyway, the original NBTV .WAV file was a much delayed response for Gary's wish to see moving video. I think I have reached the limit of the operational options for this particular CCD video camera, but I am far from unhappy with the results.
Gary,
I don't know why you only got one file, but there is a possible clue as to what is happening. Your cropped AVI, which plays on your system, does not play on mine. So, if you could send your WindowsMedia Player version, I will cross check it with mine. I would not be surprised if I had an older version. I will check that my trying to play a suspect file on a brand new laptop at this end, which should have the latest version of the media player software.
I have been slow to get back up to speed on my many projects since the death of my wife a year ago. We were married for 46 years and it has been a tough year. I must say that the last few weeks have had a very welcome impact on my mood and energy!
All the best,
Ralph
