Baird ratio
Baird ratio
Postby Lowtone » Mon Mar 12, 2018 9:08 am
Hello,
The ratio of the Baird system was 3:7 with 30 lines. But the real ratio was 1:2; wich is a bit wider.
In order to make it happen, 3 lines on each side were wider than the lines composing the main section of the picture.
Wich leaves us with 24 lines of normal width and 6 larger lines.
If one normal line is 1 pixel wide, how wide are the 6 larger lines ?
r a d i o P T T v i s i o n
Lowtone
Re: Baird ratio
Postby smeezekitty » Mon Mar 12, 2018 11:33 am
Code: Select all
(24*1 + 6*x)/70 = 1/2
24 + 6*x = 70/2
48 + 12*x = 70
12x = 22
x = 22/12 = 1.8333
The 6 larger lines are 1.8333 or 11/6 times wider than the other lines.
smeezekitty
Re: Baird ratio
Postby Panrock » Mon Mar 12, 2018 12:09 pm
If the total width of the picture remains at 30 pixels and the 24 lines are 1 pixel wide, then the 6 lines cannot be wider.
But if they are wider, then the 24 lines must either be less than 1 pixel wide or the total picture width must be greater than 30 pixels.
In this case, the aspect ratio differs by 7/6, so the total picture width is: 7/6 x 30 pixels or 210/6 pixels. The width of the 6 fat lines taken together then is (210/6 - 24) pixels. Divide this by 6 and your answer is 1.833 pixels per fat line.
Re: Baird ratio
Postby Lowtone » Sun Mar 25, 2018 8:38 am
Thanks a lot for the math :!:
Code: Select all
Photographic reproduction of a picture broadcasted from London ( système Baird ), 30 scanning stripes ( 2100 elements ).
Notice the 3 larger stripes on the two lateral sides of the picture.
Lowtone
Users browsing this forum: No registered users and 95 guests
