I've come across this:
https://www.grand-illusions.com/televisor-kit-c2x24326293
From Grand Illusions (cost: £43 + p&p).
I wonder if anyone has bought one of these. Anyone know exactly what the signal format is?
Regards,
Lawrence
Klaas Robers wrote:When looking again to both recodings I see that the picture quality, sharpness and so on, is visibly better on Andrews. Also in the recording of Grand Illusions the frame sync is 3 or 4 lines out of phase. You see at the left side of the picture 3 or 4 lines that should be at the right side, so you mis there a stroke. I know that the MUTR televisor tends to mis-synchronise for one line, + or -, but I never saw this large amount. I fear that the paper label with sync information (the black squares) was not glued in the right position.
But in Andrews recording there is a slight instability in the synchronisation, the picture is somewhat moving up and down. I know, it is difficult to get that better, my monitor also suffers from that, however this is not visible in the Illusions recording. And I saw in your recording Andrew, some small black dots moving slowly up or down. Any idea where they are generated?
I have the feeling that you recorded picture and sound separatedly and you joined them afterwards again, because I see in the singing no coincidence in sound and picture, especially at the end. As far as I remember, this was not in the original video and sound.
Users browsing this forum: No registered users and 78 guests
