Yes, indeed! I want my Phonovision!Viewmaster wrote:There's discussion on other threads about storing digitally......
But as true NBTV believers in the faith(!) shouldn't we be designing and building cutter heads and obtaining shellac discs to record NBTV onto records? Phonovision!
And there is something almost mesmerising about watching the cut thread collect on the surface of an acetate recording blank.Viewmaster wrote:Recording onto CD is so clinical and lacks all the excitment of such things as neeedle sharpening on playback and accidentally hitting the reproducer's arm...
....sccccreeeeeeeeech!
Actually, Mr. Baird describes a composite single audio/video groove as one possible embodiment in his Phonovision patent. The video channel is hill-and-dale, the audio channel is lateral. See page 3, column 1, lines 41 through 46 of British Patent 289,104, filed 15 October 1926, in the Patent and Articles section of the forum.Viewmaster wrote:Getting the groove modulation correct. Having two tracks, two cutting heads and two playback reproducers, one for vision and the other for audio....just think about all those Phonovision problems and what we are all missing with our clinical CDs.
I always thought that cylinders were the way to go. My turn of the 20th century Edison "Home" machine has a recording head attachment. The recording quality from beginning to end is consistent, although mediocre, and there is no possibility of the recording horn introducing any gamma factor. I need to find some more blank wax cylinders. Two minutes of recording does not go very far.DrZarkov wrote:If we want to have it affordable I suggest to use cylinder records, a phonograph (in original/british meaning of the word) turned for NBTV, a "Visiograph" system. It is much easier to make your own cylinder recordings than disc recordings. The advantages: The length of the grove does not change from the beginning to the end, that means constant quality (at a 12 inch disc the quality gets worse to the middle of the record, maybe viewable with NBTV.
The outside-in format never made sense to me either. Actually, the original 33-1/3 rpm discs developed by Western Electric in 1926 for the "Vitaphone" sound films are 16 inch with and an inside-out, hill-and-dale recording format. Radio broadcasters later adopted this system for their transcription discs, so most surviving radio programmes from the 1930s and 1940s are in this format.Klaas Robers wrote:This discussion reminds me to a related problem.
You all still know that grammophone records are played from the outer edge to the centre. But why this way?
CD's are played from the centre outwards. Much easier, starts at the same diametre, regardless the size of the disc, 12 cm, 8 cm of whatever. All optical discs do: the old Laservision, DVD, Blu-ray. But why grammophone records not?
This is good, Andrew. Now we have to work on ShellacVideo, or perhaps CylindricalVideo, if we opt for cylinders.Andrew Davie wrote:http://www.vinylvideo.com/
DrZarkov wrote:I found it less amazing how much they ask for it...
Viewmaster wrote:First problem to be solved is the inter coupling of the Nipkow camera disc to the cylinder rotation and the grooves per picture frame protocol to be adopted. Direct coupling to Nipkow at 12.5 revs per sec is too fast for cylinder if recording time is to be for some minutes.
How fast did the old cylinders run?
Viewmaster wrote:Of course, this machine must really have old valves as amplifiers for the head and playback.....preferably bright emitters!
Transistors and ICs are banned.
Users browsing this forum: No registered users and 99 guests
