Stephen wrote:In the case of the standard 2.1875 inch diameter cylinder rotating at 160 rpm (2.66667 rev/sec), the surface speed is 2.1875×pi×2.66667 = 18.33 inches per second (ips). With a standard 2.7 mil (.0027 inch) conical stylus, the minimum reproduceable wavelength would be .0054 inch. Therefore, the maximum reproduceable frequency would be 18.33/.0054 = 3394 Hz. With a special elliptical stylus that would have a minimum dimension of 1.2 mil, the maximum reproduceable frequency would be 18.33/.0024 = 7638 Hz.
This indicates that even with a special elliptical stylus, the standard cylinder rotating at 160 rpm could not adequately reproduce our standard NBTV signals. We would need to use the larger "Concert" cylinders or a higher cylinder speed. .
Thanks for all those calculations Stephen.
But we have always known, haven't we, that a standard cylinder would only produce a degraded NBTV image? I certainly did mention this some time ago that I was prepared to accept this.
I suppose it's all a case of what one is trying to achieve. Either a good reproducing system......use a CD for first choice or discs as you indicated, or an historic project just to see how cylinders and NBTV combined might look. Edison was going along this track but abandoned the idea as film came in.
Concert cylinder blanks are £37 each by the way.
If I ever built a combined NBTV/cylinder machine I would call it a "Edikow"
in memory of Edison and Nipkow...my proposed seperate cylinder machine just an"Edi"
Anyway, the solving of the cyl sync problem is an interesting challenge even if it eventually just leads to a crappy looking image
