Stephen wrote:Good point, Albert. I checked the specifications on some of the Ortofon pickups and mid-range separation is on the order of 25 db-not so good.Viewmaster wrote:I am not up on inter channel breakthro' figures on discs, and how many db's down one channel is on the other, but with audio only recordings this is not troublesome.
But for NBTV with audio on one channel and vision on the other would this not be a very great problem on a stereo cut disc/cylinder?..........
........The slightest breakthro' would lead to the NBTV whining sound being heard and the sound would also modulate the picture.
I remember what sound breakthrough looked like on the 405 line TV...not a pretty sight.
Now this channel separation is with the channels normally phased for the 45/45 system. With one of the channels wired out-of-phase for the "Baird" hill-and-dale video/side-to-side audio channel system, this might change. I need to think that over.
Before you do, check out the prices of stereo disc cutters. WOW!
Now I might consider going backwards in time to the guts of an old moving iron loudspeaker.
Horse shoe magnet/coil/armature with a cutter stuck on the end!
It would certainly look the part on a NBTV/phonocylinder machine.
Mono and cheap. Simple and probably no good!
I have bought a blank wax cylinder now (fools rush in!) and when I have
the time(!) will get an old moving iron LS and set about putting a stylus on it...then mount it on my model engineers lathe with the cylinder revolving in the lathe chuck. etc etc. Just to see what it can do with a range of various audio freq. inputs.
