Help for motor control problems
Postby perteree » Mon Nov 02, 2020 5:06 pm
Excuse me, the motor has 4 interfaces, positive and negative, PWM wave intelligent temperature control, motor speed measurement, how to control it? ?
What color tent stove would you like?
perteree
Re: Help for motor control problems
Postby Steve Anderson » Mon Nov 02, 2020 5:46 pm
A little more detail would help others to resolve the question. What motor? Where did you get it from? Any data with it? Right now for all we know it might be an old tractor motor. If you want answers give us some data to work with...
Sorry to be so blunt, but we often get questions as vague as this one...
P.S. I used to live in HK, Sai Kung, but that was 25 years ago.
Postby Harry Dalek » Tue Nov 03, 2020 7:46 pm
I think this should be moved to off Topic but at first i was thinking this was a HDD BLDC motor but now i am not to sure mind reader i am not as Yoda would say hang on i think he is ! :shock:
Postby Cici » Tue Nov 24, 2020 4:53 pm
Some applications require only torque control, other applications require stable speed, and some require extremely precise position control. These different requirements require multiple solutions.
Cici
Postby Daicy » Fri Oct 15, 2021 6:42 pm
As the temperature increases, Rs will increase, Ke and Kt will decrease, which will affect the increase in mechanical constants. Therefore, a high-performance servo motor has a temperature constant, which corresponds to the temperature rise curve of the motor itself, and dynamically modifies the electrical constant, back electromotive force constant, torque and mechanical constant of the motor.
Daicy
