That sounds like an intriguing approach for a fully mechanical reproducer/televisor! There would be no moving armature, so no resonances to adversely impact frequency response linearity up to the resolution limit of the gas jet. One could even share the gas supply with a Stirling engine to drive the machine for totally non-electric operation.DrZarkov wrote:If you take a gas like Buthan or Propane instead of air, you can even make a fully mechanical televisor, the surpassing gas controlled by the groove feeding a flame replacing the LEDs. In fact, this has be done, the so called "Flammophon". (for sound, not for TV.) The idea behind it was that a flame expands the surrounding air. So you could modulate the air directly by a flame instead of a membrane. It worked, but was no success. I don't know if any Flammophones survived or burned down with their owners...
I have been waiting for a further report from Roland, who is actively constructing a non-electric system. It has been a while since his last report.DrZarkov wrote:BTW: What had happened to the complete mechanical TV projects? Any news?
Using a Flammophon-type NBTV phonograph, you could record and play the fire brigade after they arrive at your house. I am sure that they would enjoy seeing a replay of themselves at work!DrZarkov wrote:The idea behind it was that a flame expands the surrounding air. So you could modulate the air directly by a flame instead of a membrane. It worked, but was no success. I don't know if any Flammophones survived or burned down with their owners...
This sounds like a very reasonable option, Albert, particularly since you can re-use the cylinders. I suppose that you could even have a sleeve as an adapter for the phonograph mandrel to accomodate the larger cylinders so that you could record or play either type.Viewmaster wrote:From time to time on eBay I have noticed Dictating Ediphone wax cylinders for sale in the USA.
Brand new in boxes of 12 and going very much cheaper than blank phonograph wax cylinders because they will not fit the phonograph being longer at just over 6 inches and slightly bigger in diameter too.
They work out at about £3 odd each delivered to UK.
Stephen wrote:This sounds like a very reasonable option, Albert, particularly since you can re-use the cylinders. I suppose that you could even have a sleeve as an adapter for the phonograph mandrel to accomodate the larger cylinders so that you could record or play either type.Viewmaster wrote:From time to time on eBay I have noticed Dictating Ediphone wax cylinders for sale in the USA.
