Viewmaster wrote:With discussions on more lines and more FPS will LEDs be able to deliver sufficient light output? Albert.
This is very interesting, Albert. As best as I can count, it appears to be about 96 lines horizontal scan. There seems to be about a 3:4 aspect ratio, so that would mean about 72 lines scanned in in the vertical direction. In other words, a 72 line 4:3 aspect ratio picture would probably be about equivalent in resolution.Viewmaster wrote:This gives a picture like enclosed. (This pic was taken from book by Larner showing Bain's early experiments in static picture transmission).
Viewmaster wrote:As I see it going from 32 to 64 lines will result in a light reduction of 1/4,
....two stops, as the 64 holes are 1/2 the dia of the 32 holes assuming disc dia is the same. Going to 80 lines is a reduction of about 1/8th in light output.
Panrock wrote:Viewmaster wrote:As I see it going from 32 to 64 lines will result in a light reduction of 1/4,
Not so. For a given disc and picture shape, doubling the number of holes will mean twice as many holes squeezed into an aperture half as wide. Meaning the holes won't be half the diameter, but a quarter - and one sixteenth of the area ! Thus you lose four stops of light, not two.
Steve
Viewmaster wrote: But I am puzzled...
Viewmaster wrote:If I doubled the number of lines on my simple black and white 32 line NBTV to 64 holes, keeping the same picture size, I would simply half the diameter of the holes in order to squeeze double the number into the same picturewidth.
Viewmaster wrote:Maybe we talk at cross purposes. You with colour and stereo in mind and me with just simple black and white NBTV.
Is that the explanation I wonder or am I just thick?
Panrock wrote:Viewmaster wrote:om on the disc for the same picture size! Remember, you've got 64 segments to fit in around the circumference now, not 32. And within each of those ½-width segments you have to fit in twice as many picture elements as before.
I'm assuming the picture shape remains the same in both cases.Viewmaster wrote:Maybe we talk at cross purposes. You with colour and stereo in mind and me with just simple black and white NBTV.
Nothing to do with colour or stereo. And by the way, it's me that has bagged the title of local thicko here, as should have been made evident by many of my past posts... That's the glory of this friendly club - I can go to the specialists who really know their oats whenever I need help.
Yes, and 48 lines would still provide a relatively bright picture with a reasonable bandwith (38.4 kHz with a Kell factor of 1.0, 26.7 kHz with a Kell factor of 0.7). The frame rate would be high enough to minimise flicker as well as display very smooth motion. Plus, it is truly a historical standard!DrZarkov wrote:The Doberitz-standard seems very nice to me. Remember this thread: http://www.taswegian.com/NBTV/forum/viewtopic.php?t=240 The second picture is 48 lines resolution. It is already a big improvement to 30 lines.
Steve Anderson wrote:....more on this I'm sure...
Users browsing this forum: No registered users and 34 guests
