Steve Anderson wrote:Viewmaster wrote:Interestingly, if you do a search for '4046' on this forum you will find many references to problems with sync using this pll. ...Certainly, the 4046 seems to cause more headaches for NBTV builders than most other items in the build. Albert.
The problems that I see NBTVers have breaks down into two areas. Firstly as Pete mentioned previously, the missing pulse causes some headaches, secondly the mechanical time-constants which vary from one build to another.
Going back to this thread...
Some discs are very light and have little inertia (darvic for example).
Others are heavy (ali or steel) and have a great deal of inertia.
As Steve mentioned the mech time- constant varies wildly from one NBTV to another.
In my recent ongoing experience with my Edikow I am fast coming to the conclusion that sync problems are caused by the incorrect mechanical inertia of the disc in relationship to the component values in the 4046 damping/feedback circuit.
It would be interesting to see how circuit component value varaitions and disc inertia varied amongth those NBTVs with and without sync problems.
Maybe we could eventially weigh our discs and so determine the best component values to use in the 4046 circuit.
