gary wrote:I am posting a hacked up utility I have been using to test my algorithms for additional NBTV formats and would appreciate any feedback but especially from anyone who can test the video on mechanical monitors of the appropriate format.
The utility supports:
NBTVA (standard 32 line)
Baird (30 line with outermost 3 lines widened)
TeKaDe/Telehor (30 lines landscape)
Visionette (24 lines, 30 frames/sec, landscape)
The utility allows video to be created from bitmaps either provided internally or user provided.
gary wrote:BTW Harry is right in that most of the formats (if not all) supported by OmniNBTV are available in the alpha version of Video2NBTV.
gary wrote:Also note that BEFORE you save the item it exists in your systems "temp" folder as something like:
NBTC7E1.tmp
Depending on your system the temp folder is usually something like
C:\Users\<your>\AppData\Local\Temp\
gary wrote:Albert, when you create the file can you play it? That's after it is created do you then get a dialog box saying:
"Video created
Press 'Viewer' button to preview
Press 'Save As..' to save to a file"
and then if you press the "viewer" button and press start does it play?
Viewmaster wrote:Yes Gary, it sure does. Everthing works OK on all formats, except the save.
Viewmaster wrote:Well thanks for that reply, Gary. I shall have to ponder upon all that and then re read it.![]()
Thanks once again for all your suggestions re OmniNBTV.
I created a 2 minute file from it in its new folder, with only line sync (no missing frame), and it saved all OK.
gary wrote:Viewmaster wrote:Well thanks for that reply, Gary. I shall have to ponder upon all that and then re read it.![]()
I just realised I may or may not have answered your question - if not don't hesitate to ask again..
gary wrote:Re the file saving - it's a shame really I would have like to have discovered the root cause of that.
Viewmaster wrote:But I now assume, rightly or wrongly, (probably wrongly!) that as a digital file can be accessed at any speed, then it is the accuracy of the PC or CD player on playback that controls what the exact freq of 400 Hz NBTV lines run at.
