If a Nipkow disc were so constructed that instead of a single spiral of holes, going around the disc once, it had two (or three, or more) turns around the disc, and the holes were therefore doubled in apparent visual vertical distance from each other, and therefore twice the size (or three, etc.), spaced twice the width apart, and the disc spun at twice (or three, etc.) the speed, then we would have the effect of a much larger disc.
To prevent the incorrect hole showing (because with a 'double' spiral, we have two holes showing over the monitor area at any time), we place a masking disc in front of the Nipkow disc, running at such a speed that for every rotation of the Nipkow disc, we have half a rotation (or 1/3, etc) of the masking disc. The masking disc so designed that it covers the hole(s) that we should NOT see for the particular orientation of the Nipkow disc. In essence, the masking disc runs at 750rpm, and the mask 'enables' the particular scanline that we SHOULD see (by the presence of a 'hole' which is in fact a whole scanline long), and the Nipkow disc runs at nx750rpm, where n is the number of spirals used.
This system would allow much larger images to be produced for a given Nipkow disc size, also allowing brighter images due to the increased hole size, but at the cost of increased 'keyhole' distortion due to the greater use of the disc area.
A
