120 and 180 line viewing
Re: 120 and 180 line viewing
Postby murphyv310 » Fri Oct 13, 2017 7:27 am
Hi.
Well I've decided to separate the EHT from the scanning. After a little search I found a suitable transformer for EHT generation. I'll leave the existing transformer for scanning .
Cheers Trevor.
murphyv310
Laboratory Assistant
Postby Harry Dalek » Fri Oct 13, 2017 1:39 pm
murphyv310 wrote:Hi.
I've done three videos in parts of what I have done.
See here:
https://youtu.be/D-86YS7JqpA
https://youtu.be/qi2EG8BZoNY
https://youtu.be/TP9wwzmpNgA
Harry & Steve.
Many thanks for your advice. I will certainly take heed of what is said.
I'd prefer separate EHT and it's not off the cards as yet.
Watch this space :D
Really great well detailed videos works very well at 240 lines .
Do you have a schematic of your set ? and the changes ? as this is on going i can understand it some times hard to jot it down on paper on PC these days .
Postby murphyv310 » Fri Oct 13, 2017 7:54 pm
Hi Harry.
Yes I'm working on it as I progress. Once I'm reasonably happy with it I will post it up here.
Cheers Trevor.
murphyv310
Postby murphyv310 » Sun Oct 15, 2017 9:12 am
240 Lines *** NOTE not 625 as per picture ****
180 lines
Hi.
Some further progress was made today.
Although the HT feed to the line output stage is stabilised it still wasn't that stable on the EHT side. Yesterday the EHT flashed over a couple of time on low brightness so I thought I should come up with a better solution.
I thought about using a series network of Avalanche diodes, after a rummage through the spares box I found a couple of dozen BYV95C Diodes. These are rated at 600v so I thought I'd put 9 in series and see if it would work. I carefully made up a network and insulated it with a few pieces of heat-shrink tubing and connected it to the CRT final anode after the smoothing circuit and feed resistors. I have to say this was a total success with 5500v on the anode irrespective of beam current, i did though up the HT to the line stage from 89v to 101v by adding an extra 10v zener to the shunt stabiliser.
I've now also got the G2 volts correct on the CRT. Focus is really good now.
I still need to do something with the frame circuit but I think the output transformer is the problem.
Cheers Trevor.
murphyv310
Postby Robonz » Sun Oct 15, 2017 3:20 pm
Nice work Trevor, that vertical distortion looks more like a vertical amplifier problem than a transformer. I could be wrong. The picture quality looks great.
Keith
Robonz
Postby murphyv310 » Tue Oct 17, 2017 4:08 am
Hi.
I ave now succeeded in uploading some new images to the old Aurora.
I now have 120/24P... 180/25P & 240/25P.
I have improved the linearity on the frame somewhat but it still isn't brilliant, i am thinking the frame TX isn't up to 25 Hz and no further improvement can be made, same with the Striations on 240 lines, usual tricks with damping hasn't really helped, as we know the line stage is in starvation mode and extra loading damps it down. I don't want to go that way as the Jelly pot Isn't designed for these low speeds and i'd rather ensure it doesn't fail, the early 900 series types are exceptionally rare and I'd like to keep it going. To be fair this is very much an experiment anyway.
You'll see the corseness of 120 lines, the picture is way off centre but again the line stage is struggling at under 4Khz.
120 lines 120/24p
180 Lines
240 Lines
120/24p
180/25p
240/25p
Cheers Trevor.
murphyv310
Postby Harry Dalek » Tue Oct 17, 2017 5:28 pm
Trevor the setup by the looks of it does like 240 line over the lower line rates ...BTW how many line rates do you want it to do ...its a 405 line monitor yes ?
Postby murphyv310 » Tue Oct 17, 2017 7:14 pm
Hi.
I'm not bothered with 405 on this set as I have another TV22 that is a complete set with cabinet. I also have around a dozen other 405 sets from 1946 to 1968.
One other set that resolves 240 well is a 1951 Decca 1000 Projection TV. It is a forward projection type onto a 4 X 3 foot screen, the flicker on such a large screen is very annoying and more noticeable.
I would say at this time I'd concentrate more on 120, 180 & 240 on my project set.
Cheers Trevor.
murphyv310
Postby Harry Dalek » Tue Oct 17, 2017 7:45 pm
They are very rare here only ever tested in Australia in the late 1940's in one city , i think Melbourne was working on 625 line and Sydney tested 405 line ..i have never seen one up close .
Like with your 120 180 240 line i have to make one to have one ,and i understand pretty neat having your set do it yourself ! :wink:
Postby murphyv310 » Fri Nov 03, 2017 9:44 am
Hi.
Since my last post the set has been playing up slightly with some hum modulating the picture.
This seems a common issue due to the old valve bases getting a little leaky and the AC from the heater pins interfering with the line oscillator and synch separator.
I have now replaced the bases in the Line Osc/Synch separator and changed the valve from an ECL80 to a 30FL1 also in the video amp from an EF91 to another 30FL1 wired as a pentode video amplifier followed by the triode section wired as a cathode follower. These mods have given me a little more line drive, also a higher video drive with better HF response.
I have also set my camera to manual settings and used a tripod for better pictures.
Cheers Trevor.
murphyv310
Postby Harry Dalek » Fri Nov 03, 2017 7:18 pm
Looks excellent Trevor linearity looks great little long on the top but better than what i have done,your circuit changes look to have payed off here .
Postby murphyv310 » Sat Nov 04, 2017 1:09 am
TV22mod2.pdf
(693.91 KiB) Downloaded 290 times
TV22mod1.pdf
(808.32 KiB) Downloaded 281 times
OK so now I have drawn up two circuits, one for the Video modification and now one of the line timebase.
I am using a Thorn 900 lopt with the full EHT overwind, this has to be the best lopt for what we are doing, using a 950 or 1400 type will still need a doubler as the resultant EHT would be too low running the timebase on starvation mode. The snag is the red topped 900 lopt's are quite rare. Don't worry though if you want to try this use the doubler.
On the diagram you'll see T1. It's the blocking oscillator transformer, virtually any will work but values may need changing, I'm using one from an early Ferranti it's small and neat so can be fitted into the bush chassis with ease. Smoothing needs to be upped a bit as the 25 hz frame can breath a bit so an extra 100uf on the main HT line is added and a 22uf on the 105 volt line to line output is added. The screen grid feed to the PL36 is fed from the main HT line via a 5K this works the best, there is also a choke fitted to the PY81 cathode and it helps to suppress some of the line stage ringing, it is one of RS's 1 amp chokes but does the trick, no timebase tuning is required as it is running on very slow speeds and low HT so the ramp up time can not really be damped.
I also will later upload the circuit of the frame timebase.
Any errors I may have missed please let me know.
Cheers Trevor.
murphyv310
Postby Harry Dalek » Sat Nov 04, 2017 11:22 pm
looks good Trevor ,i like also on old school hand drawn schematics .
Thanks for posting .
Postby Lowtone » Fri Nov 10, 2017 4:44 am
180 line testcard C :mrgreen: nice touch
r a d i o P T T v i s i o n
Lowtone
Postby murphyv310 » Sat Nov 18, 2017 7:32 am
Hi.
I've not been doing much on this or working out how to do syncs for mechanical standards. The shed is quite cold and I've not been at my best. Other things have had to take preference. Will get back into the swing of things soon.
Cheers Trevor.
murphyv310
