On the horizontal input a frame scan is placed, with superimposed a fast square wave (I guess 200 kHz) which is duty cycle modulated with the video. Then you get two pictures next to each other, one in negative and one in positive. The disadvantage is that, if you do it straight forward, you have no gamma correction. With direct Z-modulation this comes in automatically.
And remind that the NBTVA-frome has an aspect ratio of 2 : 3 in portrait orientation. Then the lines tend to get closer. Then you may defocus somewhat.....
I remember Jeremy's item in the newsletter, it was quite some years ago. Indirectly it was the trigger for my use of PWM beam modulation even though there's no direct connection between the two, how that happened I don't know.
It uses a PWM waveform to shift the beam left (or right) to create both a negative and a positive image. It is quite a clever idea.
There's no reason why it couldn't be done in the vertical direction with one image above the other, but due to the aspect ratio of NBTV less shift is required if done horizontally.
You could view this as an extreme example of spot-wobble using a varying duty square wave! The duty-cycle of the square-wave is modulated by the video, just as in the case of the PWM grid modulation. The difference primarily is that the square-wave is added to the horizontal ramp instead of the grid circuit which if you're using a commercially made 'scope is easier.
Harry Dalek wrote:I wonder if hes still doing NBTV Steve? ....can you post these things up ? if not the original a hand drawn copy ?
Steve Anderson wrote:After the 'shift oscillator' there are two NOR gates, at the output of the second one you should be getting an approx. 35kHz square-wave, the duty-cycle, not the frequency, should vary with the video signal.
At the op-amp end of the 'Frame Scan Output' 1k resistor you should see a 12.5Hz negative-going ramp (timebase). There will probably be some interaction between the signals, why the mixing resistors (1k) are such a low value I don't know.
I realise that you're not using an exact copy of Jeremy's circuit, it may help to post a schematic of whatever you have built.
Steve Anderson wrote:The first possible problem area may be the use of a NE5534 which isn't a single-supply op-amp. I say maybe because it might just operate as intended. If the video waveform at its output looks OK then perhaps you've gotten away with it - note: the waveform will be inverted (deliberate). The AN1358 is a single-supply dual op-amp, so that's fine. Jeremy used a LM348 quad single-supply op-amp.
The use of the 4060 is an error. The 35kHz waveform needs to be either a sawtooth or a triangle. Use a 555 to generate this and feed the triangle waveform into pin 3 of the 311. The triangle waveform with a +12V supply will be approx. 4V p-p, from +4V to +8V. A 555 used convetionally as an astable doesn't generate a linear triangle but for this application it's OK - but could be better.
The video part of the signal (311, pin 2) should be in the same range as the triangle waveform, the syncs will be higher than +8V but that doesn't matter, we only need the picture information here. You may need to increase the value of the 22k feedback resistor to get the gain you need (pins 2-6 of the 5534), possibly increase the value of the 15k resistor is series with the pot to make setting the output DC level easier.
The output of the 311 is now the desired PWM variable-duty square-wave. Disconnect the 25uF cap to view this on a 'scope. The posting of Ron Jones's laser-link above explains the principle quite well. What you are trying to achieve is shown in the sketch below.
Lastly, the circuit downstream of the 311 isn't going to work well, if at all. I'll have a think on this and post an update a little later,
Later...I just realised that the LM348 isn't single supply, I got it confused with the LM324 which IS single-supply. Either that was a typo by Jeremy or he used a negative supply not shown in the circuit.
Steve Anderson wrote:Yep, the 5534 is primarily an audio chip for low-noise applications, turntable pre-amps, microphones etc.. In most applications it was used with dual supplies, where used single-supply the inputs are close to the centre of the supply voltage, e.g. +12V if the supply is +24V. The inputs stop behaving if they get within 2-3V of either supply, or in this case ground/0V. The same applies to 741s, LM348s and the like, I don't know of a single single-supply op-amp i.e. not a dual or a quad, they must be around though I guess. The LM358 is a dual version of the LM324 quad single-supply op-amp.
In the laser circuit above the 741 inputs are close to half the supply voltage and the signal is small, a microphone output.
The major concern I have with the cap on the output of the 4060 is the the internal current-limiting circuit is being used to provide a current source to charge/discharge the cap. It is meant for protection of the device and under normal circumstances should never be activated, it also increases heat dissipation and power supply current. Yes, change it to a 555.
I've still to look at the last part, I got dragged away by something else...
