Harry Dalek wrote:...so you think those circuits using a single supply for their opamp should really be a dual supply ? So this should have been a dual supply ...this was the first 741 circuit i had seen with a single supply i always thought the only way to use a 741 was with a dual power supply.
Dual-supply op-amps can be used single supply but the inputs are not designed to go any closer than 2-3V more positive than the negative supply or in this case, ground/0V. Single supply op-amp inputs can usually go to ground/0V or often slightly negative (300mV or so) and the device functions correctly. Not always true for the positive supply though there are exceptions.
Single-supply op-amps can be used with dual supplies as well, but there's not much point. Often single-supply op-amps have poorer specifications than the dual-supply versions, but used in the manner we generally do here there's no practical difference. Many have a lower supply voltage rating, say 18V which is useless with +/-12V supplies.
As for using the 5534 in head-amps on a single supply, it all depends on the biasing, the voltage on the two input pins, if they are at least 2-3V above ground, and 2-3V away from the supply all should be well...much in the manner of that laser-link microphone amplifier.
