Steve Anderson wrote:Harry, I've spent a little time studying Jeremy's design and I've sent him an e-mail asking if he used an additional negative (probably -12V) supply. If he didn't I'm starting to wonder how it functions. I'll await his reply and given some work-bench space maybe breadboard it.
The concept is definitely sound, I'm trying to simplify the last stage somewhat.
Steve Anderson wrote:Well I've not had a reply from Jeremy as yet...we'll see. I have had a go at coming up with an alternate last stage for this and it's no simpler than Jeremy's, so it's probably best to stick with something that has been demonstrated to work.
Steve Anderson wrote:Getting Germanium transistors can't be that easy these days, but a source could be early transistor radios from the late 50s/early 60s. I haven't used any in many decades.
Seeing as you're using stripboard a useful tool is a 'spot-face cutter' for breaking the tracks. Picture attached. Mine is a standard 3.5mm drill bit with a plastic handle molded on. Others seem to use a fluted design, but I guess they work equally well. They're quite cheap even though I have to get them from the UK, not seen them here.
They can be sharpened on a standard grinder...usually every 2-3 years. Probably more frequently if using the fibreglass-based stripboard versions, which I don't.
Agreed, my supplier here only goes up to 2M in cermet trimmers, and only 500k in carbon. Even then, the 2M cermet trimmers are only available in either 15 or 25 turn varieties, no single-turn.
You might try reducing the trimmer to 470/500k, the resistor connected to the wiper to 15k, and increasing the cap to 33nF...should work, but not 100% certain. Or pro-rata for other values,
Steve Anderson wrote:Something I just thought of...and the photos above seem to confirm this...with these high resistance values the scope input, even if it's 10M will possibly load the waveform such that it can't reach the logic threshold of the 4011. It's easy to get caught out by this, I have several times. In most circuits you can ignore the scope loading, but here, maybe not.
You can get 'active probes' for 'scopes which have input resistances of gig-ohms, 1000M, but they're not cheap, often limited to a maximum input of 50V and have a limited bandwidth, say 10MHz...unless your pockets are very deep.
Users browsing this forum: No registered users and 18 guests
