Buzz coil CRT
Buzz coil CRT
Postby McGee2021 » Tue Nov 24, 2015 11:52 am
I have a very large collection of buzz coils, which would have been used in early automobiles for there ignition. I salvaged a CRT from a b+w tv, and decided to experiment.
Setup
(884.72 KiB) Not downloaded yet
(864.21 KiB) Not downloaded yet
Coil
(1.14 MiB) Not downloaded yet
McGee2021
Re: Buzz coil CRT
Postby dominicbeesley » Tue Nov 24, 2015 11:58 pm
Looks like you've got the start of a televisor there! Next thing feed a signal in to the cathode or grid and then find some way of making the time bases. At one point I started on a meccano CRT + mechanically moved magnets idea...
dominicbeesley
Re: Buzz coil CRT
Postby Klaas Robers » Thu Nov 26, 2015 2:53 am
The buzzing ignition coils are from the Ford model T. You can make a simple spark transmitter from them. However these experiments are also nice to do. But this is pulsed alternating current, not useful for a CRT picture tube. This tube needs, I guess, 10 kV DC for the accelerator high voltage.
Has the tube a recognition code? When you search on it you might find the characteristic voltages.
Re: Buzz coil CRT
Postby McGee2021 » Thu Nov 26, 2015 4:08 am
Klaas Robers wrote:The buzzing ignition coils are from the Ford model T. You can make a simple spark transmitter from them. However these experiments are also nice to do. But this is pulsed alternating current, not useful for a CRT picture tube. This tube needs, I guess, 10 kV DC for the accelerator high voltage.
The coil did manage to make a small spot on the screen, because I didn't have the electro magnets on. They were used in most early cars, up to the 1930s. My collection includes about 150, most of them from old family cars. I typed in the recognition code on the web and couldn't find anything. I also have made around three spark transmitters, and some of the could I have require an AC input and output.
McGee2021
Re: Buzz coil CRT
Postby jjester6000 » Wed Aug 15, 2018 4:54 am
McGee2021 wrote:I have a very large collection of buzz coils, which would have been used in early automobiles for there ignition. I salvaged a CRT from a b+w tv, and decided to experiment.
The attachment image.jpeg is no longer available
You just gave me a CAZY idea?
Recently, I have been working on my own unsealed form of the Image Dissector Tube that I call the Video Crudiscope Tube.
It is not fully working yet, but I have gotton it to respond to light which is kind of amazing for something made of mostly JB Weld and wood. Instead of using a vacuum pump, what if I could use one of the vacuum lines from comming off the GM 250 straight 6 Stovebolt from my 1974 GMC C1500 Pickup Truck?
I could wire the tube to the ignition coil parallel to the distributer cap, and also maybe pull a plug wire and run one axis of deflection off the distributer. Of course the engine would run loke absolute garbage, but this is so crazy it might just work!
jjester6000
Re: Buzz coil CRT
Postby FlyMario » Wed Aug 15, 2018 6:12 am
I nearly just shot lemonade out my nose. Mechanically moved magnets on a CRT? Say what? All I can picture is legos moving magnets back and forth to make the electron beam move H and V.
Too bad that post is from 2015. I would love to see that.
FlyMario
