Updated "ROM-Scanners" and the like.
Postby Steve Anderson » Sun Jan 10, 2021 12:41 am
It's been quite a while since the two versions of the "ROM-scanners" were published by Ralph Taggart and Klaas Robers. Things in terms of non-volatile memory have moved on greatly since then. I'm looking ahead once the NBTV/SSTV-625 up-convertor is completed to possibly my next project.
It's basically the same concept but brought up-to-date, no EPROMs, but using Flash memory allowing much greater storage and no UV erasure boxes which would require a total reprogramming of the memory...and no 12.5V-25V programming voltages required. Instead using Flash memory which would allow a replacement of a single image if desired. Plus the amount of storage is vast compared to EPROMs as well as being only 8-pin instead of 28-pin plus.
Image below shows a size comparison even though not the devices in question. The small device is SOIC, more correctly called SOIJ these days and is perfectly hand-solderable.
The small device is a 64Mb (64mega-bit or 8mega-byte) Flash non-volatile memory device which costs GBP about 2.50 or US$3.50. (Size corrected 10/01/21).
Now, the reason I mention this at this stage is what would you guys like in terms of functionality/features? Simple programming from a USB port is an obvious one. An animation sequence is another, possibly with sound, others?
This could also be applied to SSTV as well.
Steve A
An alternative is a USB Flash-drive/memory-stick, but if you've even just glanced at the protocol required for USB you'll realise it's beyond mere mortals, OK, it's beyond me! Though I have dabbled with SD cards in the past and they are a possibility...aside from the initial configuration they're not vastly different to the Flash memory above. If you have a few SD cards of 2GB or less kicking around in the dust at the bottom of a drawer, hang on to them. It's probably wise to check they still work as they'll be quite some years old by now.
Postby acl » Sun Jan 10, 2021 9:20 pm
Looks like a good Idea,
Graham Lewis did produce one with NBTV pictures immedded in a PIC and used an analogue input to change pictures. I was impressed with Andrews method of using a SD card to store images. One Idea would be to produce a convertor to compliment the NBTV/SSTV/ to 625 line convertor with one that produced SSTV/NBTV signals selectable from either a PAL camera or JPG images stored on a SD card. The unit would have a reader and CCIR signal input.
Regards Chris
acl
Re: Updated "ROM-Scanners" and the like.
Postby Steve Anderson » Sun Jan 10, 2021 11:05 pm
Some years ago I did a Photo-to-SSTV device but I've never published it. I used it to generate the pictures shown in the MkI up-converter examples. It was a bit labour intensive requiring several manual steps to achieve the SSTV output. One day I should re-visit it. Though decompressing a JPEG might be quite a challenge.
I think somewhere lost in time I did make a start on 625-SSTV, but using the cheap cameras usually available the results were somewhat disappointing. And seeing that SSTV is really a sequence of stills there didn't seem any point so I took it no further.
But certainly a monochrome TIFF or BMP to SSTV is entirely possible...as noted above, I've done it before. It just needs some automation thrown at it!
Postby Harry Dalek » Mon Jan 11, 2021 3:11 pm
I a total dummy on these things ,i don't know how this relates to your other project so i googled what the hell are these things ! ; )
Got this
Read-only memory is a type of non-volatile memory used in computers and other electronic devices. Data stored in ROM cannot be electronically modified after the manufacture of the memory device.
So i think it means you use this to program the rom and its stuck in there for good ?
BIt like a 2021 version a record !
Do take it Steve that some of us have less brain cells to work with think i need some Rom's in my head ! 8)
Postby Steve Anderson » Mon Jan 11, 2021 5:06 pm
The original (and now very old) EPROMs (Erasable Programmable Read-Only Memory) had a quartz window in the case/package. (Photo follows). You programmed them from a blank device using a 12.5-25V supply on one pin and using an EPROM programmer. If you wanted to change/update the contents you had to expose the quartz window to quite a high dose of UV light for 15-20 minutes. Then program it all again...
DIL 28-pin EPROM 1.jpg (37.57 KiB) Viewed 11728 times
EPROM UV erasure.jpg (32.23 KiB) Viewed 11728 times
You put the devices to be erased in the front drawer, set the timer........and waited....some even made a 'ding' sound, much like an egg-timer, to let you know it was 'cooked'!
Once programmed you covered the window with some sticky opaque tape, otherwise sunlight with its UV content would slowly (weeks/months) erase the device. Maybe not much of a problem in the UK!
Then came EEPROMs, (Electrically Erasable Programmable Read Only Memory). Same idea, but now no Quartz window, no high voltage required, no UV erasure box, and took less than a second to erase the device. They're still made and available but they are nearing their twilight years, Flash memory is flavour of the month currently. It's what's used in the micros for various projects here as well as your USB Flash-Drives.
Imagine having to wait 15-20 minutes to erase a USB drive, where everything on it is deleted, no way to just delete one file...then put them all back?
Postby Harry Dalek » Mon Jan 11, 2021 5:26 pm
I have a fair few of the EPROM with uv window ,i sort of knew they get wiped via uV light window...i don't think you would need a device you could do it passive way the sun is a UV monster leave it in day light for a bit .
Yes all these form of memory are confusing for those that never tried them and even more so how to use them .
Postby Steve Anderson » Mon Jan 11, 2021 5:32 pm
I mentioned before, I used to have bucket-loads of them, but as time went on I realised they were as good as useless...so in the bin they went. That was probably 25 years ago!
Going back to your posting, there are 'One-Time Prorammable' versions. Exactly the same as the EPROMs mentioned above, but no quartz window, once programmed there's no way to erase them. Once you have proven code and a marketable device/product you should never need to change the code. So these devices were used in mass production. The absence of the quartz window made them far cheaper for manufacturers, it was quite an expensive operation to include it...and of course the devices didn't self-erase when exposed to sunlight.
"I'm sorry sir, we cannot update the software with the devices fitted in your version. You'll have to buy a new one," Me? Cynical? Nah!
Thankfully I think those days are gone...
Postby Harry Dalek » Mon Jan 11, 2021 5:55 pm
Steve Anderson wrote:I mentioned before, I used to have bucket-loads of them, but as time went on I realised they were as good as useless...so in the bin they went. That was probably 25 years ago!
I think i like the idea fixing a mistake with the reprogrammable versions pity they are not drop in copies good to experiment till you got it right ,what do you do in this case as in testing that the programming it correct ? if it can only be written to the ic before testing you would have to buy a few just in case ....speculating !
I am a hoarder :roll: can't bring my self to chuck those ics in the bin its always just in case you better not :oops:
Postby Steve Anderson » Mon Jan 11, 2021 6:11 pm
Harry Dalek wrote:I am a hoarder :roll: can't bring my self to chuck those ics in the bin its always just in case you better not :oops:
OK, a couple of questions...have you got a UV eraser? Have you got an EPROM programmer? Do you want to spend money or barter/trade them with something? There'll be many gathering dust on peoples shelves for sure. A lot of the hobbyist versions required something like a BBC-B computer to interface to. Though RS232 versions with DOS based software were the majority...
And of course you're limited by the small amount of memory EPROMs possess. I can't imagine anyone proposing using EPROMs these days, but possibly someone might...they're also quite slow compared to current memory chips...
I'm not putting a 'downer' on them. they were good in their time, but honestly that time has long passed..
It raises an interesting question. I'm interested in valve/tube technology, it's so different to Silicon. Will anyone, say in 30 years time, look at EPROMs the same way? The problem is what will be different in 30 years time? One heck of a lot for sure...but I doubt I'll be around to witness it!
Postby Harry Dalek » Mon Jan 11, 2021 8:07 pm
NO i think the reason i kept them was i read some where in one of the news letters years back there was talk of using them as alight pickup so nothing to do with what they are used for i was thinking i might try that out .
Yes having little memory is a big problem i suppose there might be some people out there that collect old parts like this ,no big problem it's the first i have remembered here i have them .
When i moved to Melbourne in 2000 i left behind some CRT's i always regretted ..i agree those vacuum Tubes are still well worth keeping and will out live as a wanted item see the prices these days for them ...they are just so interesting and they glow ! does it get any better !
Postby Andrew Davie » Thu Feb 04, 2021 11:00 pm
Steve Anderson wrote:You put the devices to be erased in the front drawer, set the timer........and waited....some even made a 'ding' sound, much like an egg-timer, to let you know it was 'cooked'!
Much of my early professional career as a video game programmer involved burning EEPROMS, erasing them, and burning 'em again for the next test. We usually had half a dozen or so cycling through the programmer/eraser, so that we could make some code changes, burn to EEPROM, test, curse, put the EEPROMS in the eraser, repeat. Perhaps 50-100 times per day....?
Postby acl » Sat Feb 06, 2021 9:32 pm
PCB for the ROMscanner
Ralph Taggart has kindly donated several production packs of his ROM-scanner project originally featured in his Image Communications Handbook. Each pack will contain of a PCB (double-sided, plated. no jumpers), a CD disk containing all image building software a SETUP ROM chip (preprogramed) and a preprogramed ROM1 chip with four sample images. The original DOS programs used are run under DOSBox on the latest windows based PCs.Anybody struggling to 'burn' EPROMS we will be running a service to produce EPROMS in the UK upon recipt of suitable image file from the member. Details to appear in the next issue of the clubs newsletter Vol. 44 No. 3.
acl
Postby Steve Anderson » Tue Feb 09, 2021 5:38 pm
Interesting to note the EPROM device is a AT27C256 type device, a OTP (One Time Programmable) EPROM version, once written to, that's it. Without the quartz widow there's no chance of an update. If the data is wrong, in the trash it goes...but the 'quartz-window version would work fine and could be re-programmed many times, without any changes to the circuit. assuming you had a UV eraser (or a strong source of sunlight plus the time) and a means of re-programming them.
There were many home-brew designs for EPROM programmers on the 'net in the 80s/90s and later into the 2000s, most using the Parallel Port interface that was prevalent at the time. Also RS232 versions, but few, if any PCs have those these days. Though you can still get 'dongles' and PCBs that emulate them via a USB port. In amongst the Windoze 'Device Manager' you'll see 'LPT1/2/3/4" and/or 'RS232' devices...along with UART serial ports, RS422/423/485 and so on when using these devices...
One source is FTDI in Glasgow UK with their 'cables' that convert USB to many different serial formats. But how long they'll continue to support RS232 and the like is open to question...RS485 has a better chance of survival as it's used in many industrial applications, e.g. CNC machines...
RS485 is basically the same as RS232 except it's a balanced data link, two wires plus ground which helps with common-mode interference common in industrial environments and uses only 5V of data rather than 232's rather flaky 'maybe' +/-5V or +/-12V voltage levels. I prefer things 'bolted down', no 'maybes' thank you...
Postby acl » Tue Feb 09, 2021 9:17 pm
Steve,
The reason why Ralph is using the OTP devices is that he kindly is supplying devices pre-programmed with set up and test images whch are known to be good. When I worked in industrial electronics all mass production boards used OTP devices. One problem we experianced was one of our systems crashed whilst being photographed with a flash camera temporily corrupting the device. That is why we cover the window with a silver label. Another trick we did to stop prying eyes trying to dissasemble our code was to transpose data lines on the PCB and use a header on the EPROM blower with the same transposition so anybody reading the EPROM would see rubbish in there.
With regards to blowing EPROMS I use a for about 60 quid off Ebay which works on USB and it works fine.
Chris Lewis
acl
Postby Steve Anderson » Sun Feb 14, 2021 2:11 pm
...and to think I threw away literally hundreds of perfectly good (windowed) EPROMs all those years ago...if I had known they'd be still used in the 2020s I would have hung on to them and sent them on to whoever wanted them...same story with tubes/valves/CRTs for most people sadly...
I should do another simple NBTV CRT display in the future, it's been a while since I have...or even a Cop McDonald P7 SSTV display, I have the CRTs. If you have a P7 CRT, wait a while, I'll be back!
Users browsing this forum: No registered users and 16 guests
