Polygon mirror Drum
Polygon mirror Drum
Postby Harry Dalek » Sat Nov 26, 2022 10:56 pm
I have always been a fan of Alan Shorts NBTV work in the newsletters ,getting close to a good 30 years now and i always liked the way he thinks the designs using the polygon mirror drums idea.
Screen 00000.jpg (159.23 KiB) Viewed 2834 times
Pretty much a finite number of straight line segments connected to form a closed polygonal chain so like standard mirror drum with out the slight mirror tilt for each mirror here they are all the same and light spot all light lines should over lap ,(my mirror drum really need to double count 43 or 44 mirrors) pretty much the size of my mirrors and what fitted on my drum used what i had ! more the better for this system and i will be using something else for framing side of it ,thinking still what i will do here .
The motor side adjusted again with what i had for the pulley belt
Felt like a little mechanical work and so looking into similar design with pretty much as always what i have laying around i did buy these mirrors a number of years ago for a future mirror drum .
Well onto construction the problem with all mirror drums is how to mount the mirrors and stopping them flying off the drum ! ,here the mirrors have a paper plastic glue backing so rather easy to mount the strip of mirrors around the drum so next was stopping them flying off with centrifugal force ,i used 2 pulley belts to hold the mirrors in place ,since i just need a thin mirror strip not much of the mirrors are needed viewable i put 2 strips of mirrors just because they fitted and holds the mirrors on the drum better than a single strip .
DSCN8691.mp4
(4.75 MiB) Downloaded 107 times
Re: Polygon mirror Drum
Postby Harry Dalek » Sat Nov 26, 2022 11:50 pm
Here testing with a quick laser knock up just to see how the mirrors are lining up , any thing under the mirrors to throw the mirrors off ...Never glue under them !
BTW i am using a scrapped U matic video drum from the early 70s for the drum and another video head for the spacer on the motor side .
DSCN8696_x264.mp4
(6.34 MiB) Downloaded 186 times
DSCN8703_Segment_0_x264.mp4
(4.31 MiB) Downloaded 191 times
Postby Harry Dalek » Sun Nov 27, 2022 7:13 pm
Today i was working on screen and laser position same on the framing side either going with a rocking mirror or rotating 4 sided little drum, so lot more to do but idea coming together .
Postby Harry Dalek » Fri Dec 02, 2022 3:29 pm
This is a learning exercise here to see if i can get a working proof of concept ,tried similar ideas in the past with far fewer line mirrors .
Looking into my screen i noticed its not 100% flat so as a screen gives a slight wavy effect to the raster line nothing to worry to much about but live and learn .
So mounted the laser today ,i was thinking of trying a luxeon or a bank of them and seeing if i could focusing it but it would of made the project much longer laser is so much easier on the optics side
Now that's the concept over with for the wanted scanning movements
DSCN9058_x264.mp4
(4.06 MiB) Downloaded 153 times
DSCN9065_x264.mp4
(10.15 MiB) Downloaded 149 times
Users browsing this forum: No registered users and 15 guests
