Today was a bit of a consolidation day, now that the motor control circuit basically works. I hooked up the oscilloscope and had a poke around looking at the signals. The surprising bit was that the signal from the IR sensors was very ugly. The top half of every second pulse was missing, with a sort of wavy flat top to it, and superimposed over the entire was a visible copy of the line pulse. Looked to me like there was an AC signal coupled to it AND the line pulse. I've seen this before, don't know what caused it.
So, I pulled out wires here and there, and had a look-see to see what was happening. One wire that seemed to be at fault was the one going to pin 3 of the 4046. I don't really know how it was wrong, but this wire 'fed' the line pulse noise and the IR signal cut-off 'into' the signal. I carefully re-seated all components and wires, double-checking against the circuit once again -- and it just sort of 'came right'. Now I have a very clean IR signal, once again - sitting around 10V with no noise. It's reasonably possible that I'd missed connecting pin 16 to ground. Not sure, just admitting possible liability
Then I replaced the cassette motor, firstly with the store-bought modern motor. I bought it, so I wanted to see how it worked. This was, I might say, a total waste of time. It's like taking away someone's rolls royce and asking them to drive a moped. The new motor clearly didn't belong. It's hard to describe, but it just felt less substantial... I junked it after less than a minute. Unfortunately, I'd re-used the small wheel/pulley that sits over the motor around which the belt wraps... and I broke it when I forced it on the new motor, so it was not useable for the original anymore. I'll have to make another, or possibly buy one -- but Jaycar doesn't carry them. So now I'm without my prime motor
There is another, sitting on the second motor that Peter Yanczer sent me, so I thought I'd try out that motor. My first impressions were not that great -- a lot of stopping and starting -- but after playing with various things like the belt tension (by repositioning the motor), and the wiring (as noted above)... it started to work pretty well.
It's clear that there are a large number of variables each of which needs to be 'pretty right' for the whole thing to work nicely. Belt tension, belt material, IR signal, motor torque, motor speed setting, 'lag', etc., etc. I've seen the thing work brilliantly, and I've seen it work very badly. Right now it's working 'well', though it takes forever to synch. I do know it's just a matter of finding the right adjustments for all the variables.
One thing I seem to have 'lost' is for the motor to turn completely off when there is no signal. It seems to want to run (slowly), but occasionally kicking into some sort of feedback loop and speeding up to warp factor 9. Again, I suspect that there are some adjustment ranges I can choose where this sort of thing doesn't happen.
I think the next thing I'll do is add a momentary switch so that I can 'frame' the scanlines correctly -- this would, I think, be best placed across the motor +12 line and would just remove power from the motor while pressed. Actually, the motor has a +20V, doesn't it. And so, I've just checked out how it all works by running the motor off the separate 12V supply, but also the LED array off the same. And it works beautifully. Lucky I accidentally designed the LED array to work off 12V.
I might even have a play driving everything off the same 12V supply, as suppled by the NBTV boards. I know, bad idea. I'll have a play, anyway, and report the results. My gut feeling is that it's going to work A-OK. I kind of like the 'elegance' of only having one rectifier/supply.
After that, I think it's about time to transfer the whole circuit from my prototype board onto the single-board with my other circuitry.
One other thing I did today was to connect up the sound circuit I built now oh-so-long ago. This is the first time that it's all been together and fully functioning as a working TV! I got to hear the people on the later tracks of the CD talking about this and that... this brought the whole thing together. Now I can turn up the volume, brightness, contrast... and the picture auto-synchs. Just need the framing momentary switch and all the mechanics will be complete!
Attached are various images taken from the latest incarnation -- using the 2nd Peter Yanczer motor -- playing with various settings on the camera. Typically, though, I'm using 1/8sec exposure at f2.5 -- whatever that means
Images are not enhanced -- they're exactly as they came out of the camera.
