by Harry Dalek » Sun Jul 08, 2018 2:50 pm
Having a good look at the problem of the dual screen over scanning ,i have adjusted the current limiting resistors on the line scan no effect apart from stretching or strinking whats in that area .
Did not try the framing but that seems fine unless i am missing some thing .
Having a think about it the last thing i can think of is this Yoke is too long for this type of Vidicon the over scanning due to this ,i am not sure what the yoke was originally used for perhaps a longer plumbicon tube..any case happy with the results .
- "Fester! Don't do that to 'Thing'"
