Frame Sequential Cathode Ray Tube Project
frame sequencer work
Postby Harry Dalek » Sun Nov 25, 2018 7:47 pm
i was testing my video frame sequencer first 3 pic's below are frame grabs displaying on PC and after out of my video frame sequencer to split the RGB colour signals to what will be 3 passive transformer modulators ...but in this case just the the scopes one .
My only problem here is as the video resets or on start up it cause's a random position of as to what colour frame starts first a manual reset gets it right and it will just stay playing the correct colour frame position till a reset of the video happens but i can't think how to do this automatically ,
Bit of a reboot here rethinking the whole project the syncing and framing modulation i should of worked out first so slowed me up here ,i am much happier with the anlaog idea ,i am just doing a bit on this each week see how it gos ,
R
Screen 00001.jpg (11.62 KiB) Viewed 7887 times
G
Screen 00000.jpg (10.56 KiB) Viewed 7887 times
B
Screen 00002.jpg (7.52 KiB) Viewed 7887 times
red out of my video frame sequencer
green out of my video frame sequencer
Blue out of my video frame sequencer
frame sequencer
Re: Frame Sequential Cathode Ray Tube Project
Postby Andrew Davie » Mon Nov 26, 2018 9:00 pm
I played a lot with making colour pictures from B&W sub-pictures when working on another platform. I'm wondering if you can go to what I call "interleaved chronocolour(TM)"? It makes a big difference to the perceived flicker. That is, on the first frame, consecutive lines being RGB RGB RGB and then on frame #2 them being GBR GBR GBR and then on frame #3 them being BRG BRG BRG. So on any given line, in 3 successive frames you see RGB. And on any given frame, in 3 successive lines you ALSO see RGB. It creates a rolling effect, but significantly reduces the flicker and totally enhances the perception of colour.
Postby Harry Dalek » Tue Nov 27, 2018 7:05 pm
Andrew Davie wrote:I played a lot with making colour pictures from B&W sub-pictures when working on another platform.
Hi Andrew
i have only really done this on a PC and only of late yes its not that hard to turn a colour photo into a split 3 colour version ...bet it was harder on the earlier computer systems you mention .
I have not heard of this Andrew doing a google Atari comes up on a search
Yes i can see how that would be an improvement i suppose it is a bit like FSC but line and frame so a bit of switching i can see even with my limited know how a way of constructing it for play back any way that is interesting .
i am playing around with one of Gary's FSC systems the 400 hz 32 line version at the moment so the 3 colour frames do a bit flicker a bit ,Gary kindly made me a 1.2khz 32 line version so that one once i use it its 3 times faster less flicker .
I am at the moment trying as simple as possible just to see if i can do it ,i think it should work now once i recontruct the deflection circuits and try it again on the colour crt ,i need 3 transformers for the passive modulation for the 3 cathodes .
Users browsing this forum: No registered users and 12 guests
