Steve Anderson wrote:Harry Dalek wrote:...There were valve car radios ! Amazing i always thought this had to Wait for Transistors .
Sure were...we had one in our 1960s Austin A40, so gutless were the electrics in the car that the lights dimmed when you turned the radio on! I had a 1969 Ford Escort, it only had a 22 Amp generator, not an alternator...so in that Austin it was probably less than 22 Amps! Thinking about it, my 1980 Suzuki 550cc motorcycle has almost the same electrical power, 20A. Yes, I still have it, I bought it new in 1980.
Most valve/tube car radios used a vibrator power supply, this generated the HT for the more conventional valves/tubes...
The car in the photo is exactly the same as our one, even the colour...Hmm, showing my age here...
For some reason this link is 'acting up', but follow where it leads to..
https://en.wikipedia.org/wiki/Vibrator_(electronic)
If you get nowhere with that link, try this one...they only mention 6V types, but there were 12V and 24V versions for trucks/buses/boats too..
http://www.radioremembered.org/vpwrsup.htmSteve A.
The attachment Austin_A40_(Farina)_Mk_I_reg_ca_1960.jpg is no longer available
I came a cross a vibrator power supply radio in the 1980s i ended up leaving a lot of stuff behind when i moved ,i knew it was for a battery use but never had any valves to test it ,i can't recall its exact size of the radio but it was no bigger than a normal valve radio from memory , may it was like you explaining for a boat looked a bit big.
I wish i still had it to show but long gone now .
Today i did a start on the 6X4 Valve DC side and Testing i gave this idea a go .Just showing the dual supply ...the 3rd valve is a copy of the positive side but with just 1 450v capacitor not in use at the moment .
Also 2 bleeder resistors not shown to drain the caps voltage after switch off 1.8meg across the positive supply caps and a 4meg across the negative side cap just what i had handy 2 watt.
Sorry its a bit messy i just drew it up for my self to construct .
Well on the positive supply i was thinking i would get double result since using both sides of the transformer windings ,i am very rusty working with these things ,looking at other circuits similar seems right ,i will have to change things for the CRT anode side i do have another on board 6N4 to work with .
The Negative result side about the same as the positive side
Checking the voltage across the dual supply its showing double the voltage i was expecting for the positive side and ground .
The positive supply looks fine for the circuits but not for the CRT anode 4 a touch low just below the 400 v minimum and a little to high on the negative side for use but that can be adjusted .
OH well first go and no mistakes causing Heating smoke and exploding capacitors so that's a good thing i say that's a good start so far
i will have to do some more reading
