Steve Anderson wrote:The DG7-32 I did for Hans was quite a few years ago, he did build it but only to a very rough stage, something distracted him and he had to stop. The deflection plates are AC-coupled (as are quite a few of your following scans/postings) as he only needed AC-coupling. For us using NBTV, SSTV, we need DC-coupling due to the low frequencies involved. SSTV has a vertical frequency of around 0.125Hz.
The actual CRT part and deflection circuits are actually the easiest part of the whole thing. The hardest part is (rather surprisingly) is the power supply. CRTs, even simple ones like this one, require many different voltages. In the middle in terms of complexity are the video, sync separation and timebases...though they're not 'a piece of cake' either.
Steve Anderson wrote:What are planning to use the ECH33 for? It's designed as an oscillator/mixer for radios. RF to IF conversion.
Likewise the 6AR7? Pentode + two signal diodes (AM detection and AGC).
The 6X5 is just an octal version of a 6X4, same limits/ratings.
True, it could well outgrow the size of the chassis you're planning to use...try and find smaller tubes...
Steve Anderson wrote:Sorry Harry, I mis-read your posting previous...Ah! that's what that old radio used, not what you are planning to use, my mistake...it makes sense now...
Steve Anderson wrote:The top-shot photo isn't that clear, get some good light, outside but not direct sunlight, and try again, a nice cloudy/overcast day being best - shouldn't be hard in Melbourne... KEEP THOSE PHOTOS. Then I hopefully can work out what is what. Then a clean-up session (but not yet) and resistance checking to confirm...do not apply power...looking at the time right now you may have to wait until tomorrow for some decent light..
It looks a much better candidate than the radio transformer, though we may have to use that as well...
I wonder what it came out of? Certainly some odd voltages (those I can see) but it looks much more useful...
Steve Anderson wrote:Much better, so here's a sketch of what I feel fairly sure of, the items in red need some clarification/updating...
Don't do anything to it for a while, tempted though you might be...clean up the terminals and remove the off-cuts, but leave the two links in my sketch in place...
Steve Anderson wrote:Right, here's my first guess as to what that transformer looks like as a schematic...
The next thing to do is measure the resistances R1 to R4 as shown, check they are connected to absolutely nothing else, all other terminals and the frame/chassis. Let me know what R1 to R4 are.
Steve Anderson wrote:DO NOT POWER IT UP YET...we're nowhere near finished yet...you can find out a lot more about transformers from resistance testing rather than voltage...
I've made assumptions, I'd rather confirm them first (or otherwise) before going further...
Sec. A, B, C and D should be very low resistance, basically unreadable on the average DVM, but just check they're not open-circuited or connected to any other secondary (or primary or earth/chassis)...
Steve Anderson wrote:Sec. A, B, C and D should be very low resistance, basically unreadable on the average DVM, but just check they're not open-circuited or connected to any other secondary (or primary or earth/chassis)...i.e. Check A-B, then A-C, A-D and so on - including the primary and chassis/earth. Do the same with Sec, B, then C, then D.
Then go through all other secondaries making notes of resistances of each winding or any shorts or differences from my schematic above. It's a tedious and boring task, but it should be done...let me know the outcome and resistance values you find...so we have no surprises later on...
