Steve Anderson wrote:As much as I like tubes I have little experience with them beyond audio devices and deflection amplifiers. How those guys designed all the RF/IF stuff in radios and TVs is beyond me. They were talented and imaginative!
I always wondered how they worked out Scanning on a CRT in the first place ,i know they would of wanted the result in their head and copy mechanical scanning so how but making it work with circuits must of been a bit of trial and error not like you could even read a book on how to do it right at the start .
I am surprised you have not built much with Valves !
Always liked Vacuum tubes glowing in the back of the old b/w set in the 60s never knowing how they worked ,all we used to do was when it stopped lighting up just pull it out and replace with out to much thought on the marvel these things are .
I have been doing a lot of CRT stuff since your help with the Anderson monitor and using tubes for one is on my to do list ,something else in this field to learn .
Time to plunder some valve/tube scope circuits, the Heathkit stuff I have here is probably a good starting point...I may go quiet on this for a few days as I think it through...the 'Phantasron' circuit looks promising..."Some users have considered the operation of this time-base to be fantastic; hence the name phantastron." No, it's not April 1st...
That's ok can't do much anyway till the weekend work and family birthdays rest of the week .
The Phantasron is the circuit i would of used here i have it on page 2 ,I was reading on Hans page about he swapped to it after a friend redesigned he's time base and being pleased with the new scanning linearity.
Many valve/tube Tektronix oscilloscopes used the Phantastron circuit, if they used it, it must be OK...
I didn't know that but good enough for them it sounds good to me !
My plan was use as much as i could that may already have been designed for NBTV and what i have handy ,there's very little really in the way of NBTV Vacuum tube circuits.
This is what i found a bit is yours too ! I was going to start it off with this one of your video inverters
Then i was going to use Jean-luc's design sync sep
I was going to use Hans Phantastron circuit out of he's scope adjusted to vertical horizontal scanning so ramp generators
As you know i wanted to use Jean-luc's deflection amplifiers but that went to pot noticing yours and was a better design not just saying that i can see it .
Now we come to Power supply which i should of should of put first as its a good thing to get out of the way here i am stuck a bit some variation in circuit needs and what range for the CRT go for close to mid or close to higher range data CRT needs ?...Since i am now fine with using 1n4007 1000v diodes making the power supply will be easier and a bit more space i know its more logical to do it this way .
Least the New Transformer is something i don't have to worry about powering this thing .
Modulation i am fine if you want to work this out ,as mentioned easiest is just put the primary of a transformer between the control grid voltage and CRT control grid and drive the modulation from the secondaries from the video amplifier sure works , Jean-luc went spot wobble so that's another way, up to you Steve if you have another idea can try all more than one if you like .
So i thought i would put what i had on mind here and it might help you work out if any thing here is a good or not so good idea for the monitor ..
